Print Labels in Job Receipt to Job
All,
In Job Receipt to Job, there doesn’t seem to be the capability to print labels after a transaction. Actions/Print exists but does nothing. I would assume that I can use the same Crystal report for Issue Material but I cannot find a way to assign a report to this. If you go into Actions/Transaction log/select a transaction/Actions again/Print Labels, it will generate a report from there. Not sure which report it is. It shows the data but the log only says Transaction report printed.
Any ideas?
Chris
If you turn on Tracing, it should capture the process of retrieving which print styles apply to that report. That should point you which Report Style ID to use.
Here’s what’s under Report Styles
(We don’t do Job Rcpt to Job, so we have no customized version of the report)
ALSO!! This is E10 But report names seem to be common from pre-E10 versions
Huge help. Got the labels printing now. Thank you.
