Print from a Dashboard
Hi Blake
How far did you get with this?
Is it still an issue?
Sent: Thu, 9 December, 2010 20:51:40
Subject: RE: [Vantage] Print from a Dashboard
Â
Unfortunately I was not able to get this to work properly.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Chris Thompson
Sent: Thursday, December 09, 2010 10:34 AM
Subject: Re: [Vantage] Print from a Dashboard
Which version are you on?
It's quite easy once you know how to do it.
Basically you need to open Dashboards > Open your dashboard > Tools > Report
Tools > Create Sample Data
Open your report in Crystal, connect to the sample data xml.
Save the report.
Go back to the dashboard.
Go to New > Report View (or Report Link) depending on which you want.
Report View allows you to view the report withing the dashboard on another tab
etc, report link opens a print preview type screen.
Enter a 'caption' > locate your crystal report > select the report data def (not
mandatory)
Save your dashboard.
That should work.
I have done quite a lot of these so let me know if you get stuck.
From: Blake Clemens <blake.clemens@... <mailto:blake.clemens%40d-m-c.com>
Sent: Thu, 9 December, 2010 15:24:25
Subject: [Vantage] Print from a Dashboard
Can someone explain to me how to add print functionality from a
dashboard I created? I created a dashboard and created a Crystal Report
that pulls information pertaining to the dashboard. Now I would like to
"hang" that Crystal Report on the dashboard. I'm sure this can be done
but I have never done it.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Save the report.
mandatory)
That should work.
Â
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
version 8.03.408B
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Save the report.
mandatory)
That should work.
From: Blake Clemens <blake.clemens@... <mailto:blake.clemens%40d-m-c.com> >
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Hopefully the instructions should be pretty similar
Sent: Thu, 9 December, 2010 15:34:32
Â
version 8.03.408B
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Chris Thompson
Save the report.
mandatory)
That should work.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Save the report.
mandatory)
That should work.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
