Print checks
If you want something different than the default Vantage form, you're going
to want to copy that and modify the copy. Then add a new form to the report
style maintenance pointing to the modified report. If you just change the
default form, the next patch you load will wipe out all your changes and you
'll be back to square one.
Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty St. Ext.
Meadville, PA 16335 p.8143336331 x236 f.8143372548 tlw@...
<mailto:tlw@...> www.chipsco.com <http://www.chipsco.com/>
Sent: Wednesday, November 07, 2001 5:56 PM
Subject: [Vantage] Print checks
Hi
How do you make the check format in vantage
just customize the default one or we have the choice in crystal to
choose the check format.
I customized it here but not sure will work correct or not
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=213858.1724159.3246510.1261774/D=egroupweb/S=17050071
83:HM/A=763352/R=0/*http://www.classmates.com/index.tf?s=5085>
Hi
