I am attempting to create an Updatable BAQ to update the Primary Bin in the PlantWhse table.
The business object for the update is erp.PlantWhseSearch and the Update Method is UpdateExt.
When I run the UBAQ it returns a list of values, allows me to double click on a row and update the Primary Bin value.
However, when a select Update I receive the following error:
Severity: Exception, Table: PlantWhseSearch, Field: , RowID: aa079fd4-d1df-42b3-86c9-50273a7b90e8, Text: Object reference not set to an instance of an object.
Query returned 1 row(s).
If you do a trace, It uses the part update BO and method. I don’t think the UpdateExt will work for PlantWhse updates (it will come back without and error, but it won’t actually change it).
I think for this to work, you might have to call he method in in advanced BPM and do it manually.
And as you can see from previous attempts, it’s not trivial.
