Primary bin assignment
I am having an issue trying to turn old bins that we no longer use to “inactive”. They are unable to be checked inactive because there is still a part that has that bin assigned as its primary.
Is there a report I can run that will show each parts assigned primary bin?
Hi Brendan,
I do not know of a report, but a BAQ on the PlantWhse table will show primary bin assignments in system.
Nancy
I have had to do this also. As Nancy stated, run a BAQ and the of you have DMT available you can update this using that if there are alot of them.
