PowerShell Rest Call - Help Needed
Generally, you should be able to pass a $select parameter to select the columns that you want. Check it out in swagger (I’m assuming that this is coming from Epicor?)
I think that column is present with every call, so you might consider filtering it out on the consuming side rather than the receiving side
How would I do that syntax wise?
I haven’t been following this thread too carefully, but I take it you’re calling the Epicor API from powershell to return results from a BAQ I think? What are you doing with the results from there?
That will be the place where you’d modify the data
It looks like you’re storing it in a variable, so you should be able to just trim off the last column either by index or by creating a new data set and filling it in from the old one and peeling off any column names you don’t want. I am sure there are 100 ways to do this
How to loop through a dataset in powershell? - Stack Overflow
If you type it into that call, the URL that it supplies you will show you how it works. This is how you do it in PostMan.
This is how you get it out of swagger.
@Banderson,
That worked perfectly for me. Got another question for you though. The data coming in has a total of 23k lines. If I just leave the data alone it seems to store it as a meta data format. I have a command to convert the data into a json format, but when I try to write that data to an array it doesn’t seem to be writing anything. Is there a clean way to get the data that comes in from the GET method and then POST that data elsewhere without all the manipulation and FOR loops that I have been using?
Finally got the code working as it should:
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add("Authorization", "Your Authorization")
$response = Invoke-RestMethod 'Where the code came from' -Method 'GET' -Headers $headers
$headers2 = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers2.Add("Content-Type", "application/json")
$response2 = Invoke-RestMethod 'Where the data is going' -Method 'POST' -Headers $headers2 -Body (ConvertTo-Json @($response.value))
$response2 | ConvertTo-Json
A few key notes for anyone trying to recreate this push data set:
  1. Power Bi only allows you to Post a total of 10k rows worth of data at a time.
  2. Power Bi only allows you to queue up 5 Post requests at a time.
    If your data is larger than that those two instances then you will need to create multiple get/post statements and use the top/skip to select 10k rows at a time
Any thought to uploading to cheap blob storage first and then do the import from there?
@Mark_Wonsil,
Not sure what blob storage is. Would you mind giving me a run down on it?
As for a push/live dataset within Power Bi, the rules would still apply.
All cloud providers provide various storage solutions with a wide array of price and performance. Amazon has S3 and Azure has its own offerings: Blob, Table, Queue, Files, etc. Price varies with performance and access characteristics (hot → archive).
Uploading to blob storage will not have the record or size limits.
Once there, you can access the Azure Blob storage from PowerBI. There’s probably a way to import from a blob into your dataverse but I haven’t tried that.
I’ll defiantly have to give this a look see. Thanks for the recommendation!
