Yes Rob, you are correct in that I did get prompted to change the
quantities. I have just checked the job tracker and the quantities
look good.
However just when I thought my day could not get any worse, I checked
one of my active jobs and the "Available For Job" tab seems to show
that nothing has been consumed when we know it has. Looking at this
screen I would draw the conculsion that nothing has been issued to
the job which is just plain wrong! I would expect the required
quantity to show 0 for all the kitted lines.
I am coming to the conclusion that the Planner WB is just buggy and
doesn't work properly... I haven't looked at it before today...
I will update you further once Epicor have taken a look at it.
Nick
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
prompted as to whether or not you want to reset the original qty...
working code to utilize the wrong job qty field.
fields being used to calculate global scheduling order - AND they
drop use of the Job Sched Code scheduling multiplier ENTIRELY as a
critical factor used to calculate the relative priorities of jobs (so
the highest priority jobs really get 1st crack at capacity).
in 405 (which we are about to start testing off line).
look good.
Nick
wrote:
>Usually when a job qty is changed (at least from Job Entry), you get
> Hmmm. Jobs carry both a production qty and ORIGINAL qty value.
> Âprogrammer who touched your version of Prod Planner WB redirected
> I wonder if (like in far too many apps recently) the last
> ÂThe changes made to the program from 305 resulted in the wrong date
> The Global Rescheduler in 403 & 404 is a perfect example of this:
> Âfunctionality testing) now supposedly addressed (nealry a year later)
> A total mess (and proof Epicor releases without doing ANY valid
> ÂProblem In 8.03.305K
> Rob
> Â
> --- On Mon, 7/21/08, nmtaylor1969 <n.taylor@...> wrote:
> From: nmtaylor1969 <n.taylor@...>
> Subject: [Vantage] Re: Potential Production Planner WorkBench
> To: vantage@yahoogroups.comand
> Date: Monday, July 21, 2008, 3:53 PM
> I have just checked the first job ( the one in which I did not
> increase the quantity ), and this would look to be showing sensible
> data. The available quantity is in sync with the on-hand quantity
> the time phase.the
> I am going to see if I can get Epicor support to look at this on
> Tuesday. I am concerned that increasing the quantity has messed
> something up somewhere.
> I will let you know the outcome...
> Be careful with upgrading. We have not gone up to 8.03.4xx due to
> problems / bugs associated with it. I believe the latest release isOn
> out now and this should have fixed many of the issues, but I would
> ask the group and see what feedback you get. 8.03.305K seems to be
> generally ok, but its not wihtout its problems... ;o(
> Nick
> --- In vantage@yahoogroups .com, "Elizabeth Hahn" <ehahn@> wrote:
> > Hi Nick,
> > I hope it's not something serious - we've been looking into
> upgrading
> > (we're still on 6.1), but this would be a serious problem for us
> also.
> > Liz
> > ____________ _________ _________ __
> > From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com]
> Behalfare
> > Of nmtaylor1969
> > Sent: Monday, July 21, 2008 12:26 PM
> > To: vantage@yahoogroups .com
> Problem In
> > 8.03.305K
> > Hi Liz,
> > The problem I am seeing is against raw materials lines associated
> > with a manufactured parent part. These are not buy direct they
> > inventory parts. The job has not been released yet therefore nojob
> > inventory transactions currently exist against it.
> > Thinking about it, the only other possible problem is that the
> > BOM's for this job where pulled from a template job currently indown
> > process. I just wonder if Vantage has got in a mess somewhere
> > the line...com> ,
> > Many thanks,
> > Nick
> > --- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> > "Elizabeth Hahn" <ehahn@> wrote:com>
> > > Nick,
> > > Is the problem part set up as make direct, instead of pull from
> > stock?
> > > Liz
> > > From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> > [mailto:vantage@yahoogroups .com <mailto:vantage%com>
> 40yahoogroups. com> ] On
> > Behalf
> > > Of nmtaylor1969
> > > Sent: Monday, July 21, 2008 12:09 PM
> > > To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups.
> > > Subject: [Vantage] Re: Potential Production Planner WorkBenchconfirms
> > Problem In
> > > 8.03.305K
> > > Ok Rob,
> > > Taking part XYZ, from the job tracker I know that we require a
> > total
> > > of 24 pcs ( 3 per and 8 units to make ). The time phase
> > > this. It is also the next job to be kitted so it's the firststock,
> > > requirement in the time phase. I have 34 pcs available in
> > andphase
> > > again this is confirmed by the on-hand quantity in the time
> > andare
> > > the part on hand status form.
> > > There are no other immediate requirements for the part and we
> > > running in a single plant, single company scenario.(
> > > So, looking at the production planner workbench I would expect
> that
> > > it would tell me I have full availability for this part, right ?
> > > Wrong! it tells me that I require 24 ( right ), I have 18
> available
> > > wrong ), a shortage of 6 ( also wrong ), and I have consumed 0
> > > right ). This scenario repeats for many parts...I
> > > Remember I have upped the quantity on this job from 4 to 8.
> > > Ill air freight the beers over if you can find the solution as
> amcom>
> > > stumped...! ;o)
> > > Many thanks,
> > > Nick
> > <mailto:vantage% 40yahoogroups. com> ,com>
> > > Robert Brown <robertb_versa@ >
> > > wrote:
> > > > Specifically what doesn't 'match up' when looking at the same
> > part
> > > using these 3 different tools?
> > > > Rob
> > > > --- On Mon, 7/21/08, nmtaylor1969 <n.taylor@> wrote:
> > > > From: nmtaylor1969 <n.taylor@>
> > > > Subject: [Vantage] Potential Production Planner WorkBench
> Problem
> > > In 8.03.305K
> > <mailto:vantage% 40yahoogroups. com>doing
> > > > Date: Monday, July 21, 2008, 12:44 PM
> > > > Can anyone tell me if they have see this problem or am I
> > > > something wrong ?8pcs
> > > > I have increased an un-released job quantity from 4 pcs to
> > torelease,
> > > > rationalise production flow. Using the job entry form I have
> > added
> > > a
> > > > new demand link to the appropriate sales order line &
> > andreleased.
> > > > Vantage then adjusts the job quantity automatically. I then
> > locked
> > > > the job quantity as production is ahead of the required date
> and
> > I
> > > > didn't want to generate unwanted planning change suggestions.
> > > > I have re-engineered the job but it has not yet been
> > Thethen
> > > > job has been re-scheduled. I have run MRP fully regen, and
> Iproduction
> > > > have run the production planning process.
> > > > When I review the "shortages for job" tab within the
> > > > planner workbench the available quantities just don't seem to
> tie
> > > up
> > > > with either the part on-hand status or the time phase.
> > > > Am I missing the point somewhere ?
> > > > Thanks,
> > > > Nick
