I am trying to import a lot of PO via DMT.with the PORel and the GL Account. When I do the import, I do not know what should the TGLCTranNum should be. If the value is wrong, then I get this error called. PORelTGLC is not available. If I leave the TGLCTranNum out, then the GL Account will not get updated.Any ideas?
Hello @TobyLai. Have you tried including the column, but just set it to 0, just like you were adding an order and having it auto generate the order number?
As per the DMT, below is the description for this field. It should auto-generate.
“Internal identifier used to keep records unique for the related record. The system generates this number by finding the last TranGLC record for the RelatedToFile-Key1-Key2 etc. and adding 1 to it.”
Thanks for the quick reply —
Issue is that I am not importing the POReleases.
Rather we have changed to a new book with a different chart of accounts, so I need to remap all to the new structure. Because Pur-UKN uses the Account on the PO, (unless I rewrite the posting rule, which I may do), I need to reinitialize the GL acct.
If I click the button, Get Default, then the DMT load works, because the new Book is pulled in.
clicking the button - fires this method - ChangeExpAcct
