I do this using parent/child UD tables but the concept is the same, it does require a fair bit of code...
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of pbparker
Sent: Wednesday, September 19, 2012 11:02 AM
Subject: [Vantage] Re: Populate dropdown based on other field value
Hmm, I'm still a little misdirected. Can anyone tell me if this can be accomplished with the customization wizards for simple search?
Basically I need to re-create the search buttons for Job, Assembly and Operation the same way they appear on MES screens.
That or are there any samples of this type of logic laying around. I checked the answerbooks on Epicweb and went through the ICE guide.
Rob Bucek
FAX: (715)284-4084
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Karen Schoenung" <kschoenung@...> wrote:
> I just wanted to say "thanks" this helped me figure out part of my own customization - and I was able to find this post with the search on Yahoo (for a change).
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "nustepvantage" <dpfiester@> wrote:
> > We are currently running Vantage 803 409C. In the past I've used the Epicombo control to bind a user defined table. Then in the EpiAppendFilters property I set up the Epicombo to filter based on another field field value in form. The filter sytax would be like:
> > MktgCampaignID = '?[ShortChar03,'']'
> > Hope this helps.
> > David
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "pbparker" <scrumbus@> wrote:
> > > So, I'm trying to create a interface that will track tooling checked out to a job and operation and then checked back in.
> > > I've got it bound to UD02 to trace history, but what I need on the form is a way for the user to select Job/Assembly/Operation in the same way that they start a production activity where the fields are bound together and the job has the searchable capability.
> > > I'm hoping this is easy, but I have the feeling it's going to be difficult. Anyone have an example or some code that creates this relationship?
