We started out using Vantage Quoting for a few years, but since we are a
machining house, we needed a tool that we could input cutters/speeds/feeds/
and material type into and get a run time out of. Vantage is not that tool.
Initially we made those calculations manually and input them into the
Vantage quotes, but we needed more accurate quotes.
We came to a fork in the road.... We chose to use the Estimating software.
The only thing we use Vantage for is to provide the quote #. This allows us
to track the quote number from Vantage to the new system and that is all.
We only capture about 10%-15% of our quotes. On those, we hand input the
information (routing and standard times) from our quoting system straight
into Vantage Part Master.
Just an FYI, at times we have quoted 2,000 or more parts in a month.
Tim Mendoza
GIDDENS INDUSTRIES
tdm@...
Tim Mendoza
GIDDENS INDUSTRIES
tdm@...
On Jun 7 2006, Todd Caughey wrote:
> We are a metal stamping job shop and don't use Vantage quoting.
> So....my poll type question is for job shops that produce discrete (or
> mostly single level BoM) parts for other companies (not internal
> assembly) - Do you use Vantage quoting or something else? And if you use
> Vantage roughly how many quotes can your people individually produce per
> month?
>Thank you very much,
>Todd Caughey
>Harvey Vogel Mfg. Co.
<< File: ATT00031.htm >>
