PO Suggestions SQL tables
Hi,
what are the table names that store all the PO suggestions data?
Thank you,
Daniel
You can determine the table and field for most anything that appears in the UI. Just select Help -> Field Help, from the menu bar.
Chose Technical Details in the Field help pane, then chose a UI field (but clicking on it).
SugPoDtl is one, I also see SugPOMsc. Have a look at the data dictionary to find out more about tables.
