Hi,
I don’t think what I am about to ask for is possible, but I am going to ask anyway. Generating suggestions calculates the PO due date by the part (or supplier part) lead time. The problem with this is you might need the part very urgently, but the PO will be generated by the buyer and be sent to the supplier with the future due date. This means if you later review the Time-Phased report or change suggestions, you would then chase this order. It means you look a bit daft as the supplier is thinking why didn’t you just request the order for the date you actually require the parts.
I did a search and it seems others have been frustrated by this but I wondered if any one had developed a solution?
jDJ
