Dora Chavarria
Mayan Technologies USA, Inc. |
Yes it is possible with a BPM
We've done something similar before
When I Check my time phased I have the suggestion for reduce the PO or cancel. If possible when I will running the PO suggestion, for that the system don't to calculate this information ? Not only in the time phased, but in the database. Is this is a configuration that can be removed ? Thanks.
With epicor 10.0.700.2
Hi Nancy,
You can check Lock qty and Lock date checkboxes in your PO release and when PO suggestion process runs it will ignore this PO for Change suggestions (reduce, increase, expedite)
Dora Chavarria
OK, thanks it's works.
If I will need to check the field, lockdate and lockqty, for each PO always. Because I never need the system say me increase, decrease. I watched for create the BPM, but the field does not exist in the database. If possible for check the field automatically ?
thanks
Nancy.
If you are below version 10.1.400.x, then the fields reside in the COMXref table. The BPM will be different between 9.05 and 10.0
Sent: Wednesday, April 20, 2016 4:09 PM
Subject: RE: [Vantage] Re: PO Suggestion (Expedite, cancel)
thanks
Nancy.
thanks
Nancy.
