Does anyone have a PO requisition procedure for E10 they’d be willing to share?
You can contact Professional Services for setup. However, you have to setup a Requisition Actions first in the system and assign the authorized user and make at least one Action ID as Mandatory Action check box enable.
Senthil,PMP
Epicor Certified Consultant
I’ve attached our End User Procedure. Our workflow is about as basic as it gets, but it should be a good starting point for you.
Requisitions.docx (264.5 KB)
Thank you very much. I looked in the Epicor user guides and couldn’t find anything.
