Hi,
Does anyone know if there is a way to stop the PO Mass Print checkbox from being marked true when Approving a PO? But, for this stop action to only happen with a defined set of vendors.
Jason
Hi,
Jason
BPM would be the way, but you’d have to determine if a Method Directive could be used of if you need to use a Data Directive.
Hi Eric,
Thanks for the help. I was able to create a Data Directive BPM to stop the mass print function when approving a PO.
Jason
