PO Line Due Date Customization
Another thing you could do, since the first release is created by the
method, is do a post-processing message. Granted, the update would already
have occurred, so it would be more informational than stopping the action.
NigelK
Sent: Thursday, May 06, 2010 7:26 PM
Subject: [Vantage] Re: PO Line Due Date Customization
Hi Sean,
Once you get your BPM installation sorted....
We have a BPM for this in place. Like Sean suggested, I had problems with
the first PO Release being created automatically so I took a slightly
different route.
I created a Pre-Processing directive on the PO.ChangeApproveSwitch BO.
The condition is: "number of rows in the <query> is not less than 1".
The query is: for each ttPOHeader where (ttPOHeader.RowMod='A' or
ttPOHeader.RowMod='U') and ttPOHeader.ApprovalStatus = 'U' , each PORel
where PORel.Company = ttPOHeader.Company and PORel.PONum = ttPOHeader.PONum
and PORel.DueDate = ?"
The Action is: raise an Exception.
Now, when the user finishes entering a new PO and tries to click the
Approval tickbox, the BPM won't let it if any line is missing the DueDate.
HTH,
Nigel.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Sean
McDaniel" <smcdaniel@...> wrote:
> This might be a bit tricky with the first release as it doesn't follow
> the creation methods for the 2nd through n releases. The first release
> is created when you save the line for the first time so my guess is that
> you can require the due date be populated pre-save on an add of a po
> line and then require the due date on the update of a release from there
> on.
> Open to other ideas :o)
Behalf
> Of Sean Toler
> Sent: Thursday, May 06, 2010 12:20 PM
> Subject: [Vantage] PO Line Due Date Customization
> Hello.
> I would like to make it so that the "Due Date" field in the PO Entry
> Line Item tab is a required field. We have an employee who is having a
> hard time remembering to give our vendors a due date, so I am hoping
> that I can remove human error from the equation.
> Does anyone know how or if this can be done?
Hello.
I would like to make it so that the "Due Date" field in the PO Entry Line Item tab is a required field. We have an employee who is having a hard time remembering to give our vendors a due date, so I am hoping that I can remove human error from the equation.
You want a customized personal performance improvement plan or a
customized vantage form?
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Sean Toler
Sent: Thursday, May 06, 2010 11:20 AM
Hello.
on.
Of Sean Toler
Hello.
Ok,
That sounds good. My question would be what would be the process to make that happen? Through scripting?
> on.
> Of Sean Toler
> Hello.
Through bpm's
Of Sean Toler
Sent: Thursday, May 06, 2010 1:19 PM
Ok,
that
there
> on.
Behalf
> Of Sean Toler
> Hello.
That sucks. It appears that we don't have the BPM module.
> Through bpm's
> Of Sean Toler
> Ok,
> that
> there
> > on.
> Behalf
> > Of Sean Toler
> > Hello.
Someone correct me if I'm wrong here but it's my understanding that BPM is
part of the system, not a separate module.
Dale Dalton
_____
Sean Toler
Sent: Thursday, May 06, 2010 1:26 PM
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Sean
> Through bpm's
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
> Of Sean Toler
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Ok,
> that
> there
> > on.
> Behalf
> > Of Sean Toler
> > Hello.
Only available from 8.03.3xx and up
Requires a license key code to be input
> Dale Dalton
> _____
> Sean Toler
> > Through bpm's
> Behalf
> > Of Sean Toler
> > Ok,
> > that
> > there
> > > on.
> > Behalf
> > > Of Sean Toler
> > > Hello.
So it might be that the codes just weren't entered. You can enter them
at any time.
Of bw2868bond
Sent: Thursday, May 06, 2010 2:52 PM
BPM is
> Dale Dalton
> _____
Behalf Of
> Sean Toler
"Sean
> > Through bpm's
On
> Behalf
> > Of Sean Toler
> > Ok,
make
follow
release
is
> > that
po
> > there
> > > on.
> > Behalf
> > > Of Sean Toler
> > > Hello.
Entry
having a
hoping
OK, we're on 8.03.404B so apparantly we should have it.
How and where does one enter the codes? (If you can't tell, I am not the one who installed Vantage on our system. That particular person works for an outside vendor who charges us $130 an hour for his time, so it'll be up to me to get BPM working I'm sure).
> at any time.
> Of bw2868bond
> BPM is
> > Dale Dalton
> > _____
> Behalf Of
> > Sean Toler
> "Sean
> > > Through bpm's
> On
> > Behalf
> > > Of Sean Toler
> > > Ok,
> make
> follow
> release
> is
> > > that
> po
> > > there
> > > > on.
> > > Behalf
> > > > Of Sean Toler
> > > > Hello.
> Entry
> having a
> hoping
Vantage 8.03 Admin Tools
There should be a link on the server and/or desktop
Of Sean Toler
Sent: Thursday, May 06, 2010 3:06 PM
> at any time.
Behalf
> Of bw2868bond
> BPM is
> > Dale Dalton
> > _____
> Behalf Of
> > Sean Toler
> "Sean
> > > Through bpm's
> On
> > Behalf
> > > Of Sean Toler
> > > Ok,
to
> make
> follow
> release
> is
> > > that
a
> po
from
> > > there
> > > > on.
.com
.com
> > > Behalf
> > > > Of Sean Toler
> > > > Hello.
> Entry
> having a
> hoping
Hi Sean,
We have a BPM for this in place. Like Sean suggested, I had problems with the first PO Release being created automatically so I took a slightly different route.
The query is: for each ttPOHeader where (ttPOHeader.RowMod='A' or ttPOHeader.RowMod='U') and ttPOHeader.ApprovalStatus = 'U' , each PORel where PORel.Company = ttPOHeader.Company and PORel.PONum = ttPOHeader.PONum and PORel.DueDate = ?"
Now, when the user finishes entering a new PO and tries to click the Approval tickbox, the BPM won't let it if any line is missing the DueDate.
HTH,
Nigel.
> on.
> Of Sean Toler
> Hello.
