You'll want to make sure that the conditions for your 4GL action make sense. I've created BPMs that will generate application errors when you say delete a record because the 4GL action assumes that ttPODetail is available, or whatever.
So either add an "if available ttPODetail then do:" clause, or make sure that the conditions of your BPM make sense for the action (e.g. "there is at least one updated row" or "there is at least one added row", etc.)
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bobschnable
Sent: Wednesday, February 24, 2010 12:08 PM
Subject: [Vantage] Re: PO BPM using ASSIGN
Got it! I was apparently thinking too hard about it, as I just modified my code to say:
for each ttPODetail:
DO:
Assign.....
And that was it. Thanks for anyone who started looking at this.
-bws
DO:
Assign.....
--- In vantage@yahoogroups.com, "Bob Schnable" <bschnable@...> wrote:
> Hello everyone,
> I am trying to write a BPM that will assign PO.Number01 the value in
> PODtl.UnitCost. My following code, as a pre-process works when you add a
> second, third, fourth etc line to a PO. But when I add the first line,
> which in many cases for us is the only line, it will not populate
> Number01. I tried adding it as a post-process, and it populates the
> field, but won't save. On refresh, it sets it back to zero. I am at a
> loss for why I can't get it to click on the first Line add.
> find first company no-lock no-error.
> find first PODetail where ttpodetail.ponum = podetail.ponum and
> ttpodetail.ordernum = podetail.ordernum no-lock.
> find first porel where podetail.ponum = porel.ponum and podetail.poline
> = porel.poline no-lock.
> /*if ttporel.trantype = "PUR-SUB" or ttporel.TranType = "PUR-MTL" then*/
> do:
> /*Message ttPOdetail.Number01 View-As Alert-Box.*/
> /*Run lib\UpdateTableBuffer.p(input BUFFER
> ttPODetail:HANDLE,'Number01','10').*/
> ttPODetail.Number01 = ttpodetail.UnitCost.
> end.
> end.
> Thanks in advance.
> Robert Schnable
> IT Applications and Business Support Associate
> 440-543-8157
> 440-543-4582 Fax
