PO approval - pending PO not showing up Vantage 8.03
Perfect, that was it. I just didn't have a "default" designated approver.
That fixed it right up. Thanks so much!
fite2be
Sent: Monday, August 19, 2013 4:36 PM
Subject: [Vantage] Re: PO approval - pending PO not showing up Vantage 8.03
Hi Mike,
Though we're on Epicor version 9.05.700C, yours sounds similar, so I hope
this helps.
The 'Buyer' in PO approval is actually the buyer account for the approval
person, not the buyer on the PO. So, if you are the designated approver, for
example, you'd want to select your name from the Buyer field. You should see
her PO in the queue with Action options to approve or reject.
Hope that helps answer it! :)
Renee
EMT International, Inc.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Mike
Abell <mabell@...> wrote:
> Guys,
> I don't really know if I've got a problem or not but I thought I'd ask. I
am testing out using "designated approvers" in Vantage instead of having a
buyer have an unlimited dollar amount which is what we have done in the
past. I've setup a buyer with a $100 limit and setup a designated approver
for her if this limit is gone over. I had enter enter a PO that was over the
limit and Vantage did indeed tell her that it had to be approved by her
designated approver before continuing. All is good I thought. However, when
I went to the designated approver's machine and went into PO Approval and
selected the buyer's name and searched, no pending PO's to approve showed
up? Am I missing something?
> Mike Abell
> Information Technology Manager
> Flexial - BOA Group - Cookeville, Tennessee
> Office: 931.432.1853 ext 302
> Mobile: 615.418.3055
> email: MAbell@...
Guys,
I don't really know if I've got a problem or not but I thought I'd ask. I am testing out using "designated approvers" in Vantage instead of having a buyer have an unlimited dollar amount which is what we have done in the past. I've setup a buyer with a $100 limit and setup a designated approver for her if this limit is gone over. I had enter enter a PO that was over the limit and Vantage did indeed tell her that it had to be approved by her designated approver before continuing. All is good I thought. However, when I went to the designated approver's machine and went into PO Approval and selected the buyer's name and searched, no pending PO's to approve showed up? Am I missing something?
Mike Abell
email: MAbell@...
Hi Mike,
Though we're on Epicor version 9.05.700C, yours sounds similar, so I hope this helps.
The 'Buyer' in PO approval is actually the buyer account for the approval person, not the buyer on the PO. So, if you are the designated approver, for example, you'd want to select your name from the Buyer field. You should see her PO in the queue with Action options to approve or reject.
Renee
--- In vantage@yahoogroups.com, Mike Abell <mabell@...> wrote:
> Guys,
> Mike Abell
> email: MAbell@...
