Thanks Aaron,
I had tried that, but did not try long enough to find the right spot.
Actually I did resolve this yesterday by simply going in menu security
and removing the data collection user from having access to Kanban
receipts in Production Management > Job Management > General Operations.
Kanban receipts still shows up, but it is grayed out and not accessible.
However, thanks for the tip. I will use it for other items, I'm sure.
Jim
Of Aaron Hoyt
Sent: Tuesday, January 16, 2007 7:22 AM
Subject: RE: [Vantage] Plant Floor help (Vantage 6.1)
Jim,
You can reduce it to a tiny dot and then hide it behind another button.
First find the buttons that are naturally above it by moving it around
the
screen full size and watch the buttons it slides behind and then reduce
the
size and stick it behind one of the buttons that is in a layer in front
of
it. I have had to use this trick in the past for the exit and help
buttons.
Good luck,
Aaron Hoyt
Vantage Plastics
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of
Moore, Jim (Anniston)
Sent: Monday, January 15, 2007 8:13 AM
Subject: [Vantage] Plant Floor help (Vantage 6.1)
We are new to Vantage 6.1. Is it possible to hide the Kanban Receipts
button on the Plant Floor clock in screen?
I have tried personalization, but I can only reduce it down to a tiny
dot. Employee's can still click on it, if they try.
I would like to either gray it out, hide it, or remove it completely.
Any ideas?
Jim Moore
"This email message is for the sole use of the intended
recipient(s) and may contain proprietary and/or confidential
information for which such intended recipients(s) may have
an obligation to treat as proprietary. Any unauthorized review,
use, disclosure, or distribution is strictly prohibited. If you are
not the intended recipient, please contact sender by reply
email and destroy all copies of this e-mail."
Jim
Of Aaron Hoyt
Jim,
the
the
of
buttons.
Good luck,
Aaron Hoyt
Vantage Plastics
Behalf Of
Any ideas?
Jim Moore
