Planning Workbench suggests moving jobs into the past
Why, when there is a safety stock in place is the system asking that I push a job date all the way back to July 8th?
The planning suggestions suggest I move everything into July 8th to alleviate all the safety stock rather than just defaulting to the current day we’re in. The date is always July 8th, it never changes.
How do I set it up the system so it asks to schedule to the current day I’m currently planning in instead of pushing the job so far into the past?
I have tried changing planning parameters to no avail.
Hi Randa,
It sounds like you do not have dynamic checked on your MRP or PO suggestion run. Is it possible that this is the problem?
Nancy
Yes it is! Thanks so much Nancy!
