Placing Jobs on Hold
While you're waiting for Epicor to address a partial hold on job
enhancement, you might consider directing some of your standard
Vantage reports to a Generic - Text Only Printer Disk File. For
example, a Progress program could read the Time Phased Material
Requirements output, get each job's scheduling priority, eliminate
ones that are "Very Low" and regenerate the report. This doesn't
entail changing Vantage source code yet allows you to utilize their
standard reports in a custom way.
Chris Robisch
425-788-2489
--- In vantage@egroups.com, Paul Siebers <paul.siebers@b...> wrote:
> Dina & Vantage group,
> I think we are encountering the same problem that you guys did.
Your
> solution (adding a priority code)was something I was hoping Vantage
> would offer, but I didn't see an easy way of implementing it. What
> exactly did you do, and how does it affect your operations?
> I have figured out I can create a new priority factor in the
Scheduling
> Priority Codes Maintenance field. The help menu doesn't tell me if
I
> can use 0 as a factor, which I would be inclined to use. If I can,
does
> it hold true that the job does no longer generate a demand on
materials.
> And can people still clock hours to a job on hold? I guess I will
be
> playing with my Vantage Test Box as well to get more insight in
priority
> codes...
> Paul
> -----Original Message-----
> From: Dina Hieber [mailto:dhieber@v...]
> Sent: Tuesday, December 05, 2000 11:33 AM
> To: vantage@egroups.com
> Subject: Re: [Vantage] Placing Jobs on Hold
> Paul,
> What we do is also unrelease the job and unengineer the job. But we
> were having problems with people thinking someone made a mistake and
> forgot to check the box. So what we did under Schedule Priority -
we
> created that states ON HOLD. We also created a bitmap -
> which is very noticable that SAYS HOLD. - This seems to have
helped us
> - but we do not put that many jobs on hold.
> Hope this helps
> Dina
> Paul Siebers wrote:
> > Hello all,
> > Maybe I am missing something; but is there a way in which a job
can be
> > placed on hold in Vantage where it doesn't generate a material and
> parts
> > demand?
> > I recently took Vantage mgmt over from the person who installed it
> > originally, and in the past we have placed jobs on hold by simply
> > unchecking the Engineered and Released boxes in the Job Entry
screen.
> > TIA,
> > Paul Siebers
> > We no longer allow attachments to files. To access/share Report
> Files, please go to the following link:
> http://www.egroups.com/files/vantage/
> > (Note: If this link does not work for you the first time you try
it,
> go to www.egroups.com, login and be sure to save your password,
choose
> My Groups, choose Vantage, then choose Files. If you save the
password,
> the link above will work the next time you try it.)
Files,
it, go
> to www.egroups.com, login and be sure to save your password, choose
My
password,
Hello all,
Maybe I am missing something; but is there a way in which a job can be
placed on hold in Vantage where it doesn't generate a material and parts
demand?
unchecking the Engineered and Released boxes in the Job Entry screen.
TIA,
Paul Siebers
What you used to do is what we do. If you really want to keep someone
else with the authority to engineer and release a job, which has
happened to us, we have closed the job. Then when we were sure we were
ready to proceed, we reopened the job.
Sent: Tuesday, December 05, 2000 10:15 AM
To: 'vantage@egroups.com'
Subject: [Vantage] Placing Jobs on Hold
Hello all,
can be
and parts
demand?
it
simply
screen.
TIA,
Paul Siebers
-------------------------- eGroups Sponsor
try it, go to www.egroups.com, login and be sure to save your password,
choose My Groups, choose Vantage, then choose Files. If you save the
password, the link above will work the next time you try it.)
Have you already started production? If you have and any labor or material
has been issued closing a job will move those costs out of wip into a
suspense or cost of goods sold account. This can cause a lot of problems for
end of the month reconciliations for accounting.
> From: Steve Wirtz [mailto:SWirtz@...]
> Sent: Tuesday, December 05, 2000 9:23 AM
> Subject: RE: [Vantage] Placing Jobs on Hold
> From: Paul Siebers [SMTP:paul.siebers@...]
> Hello all,
> can be
> and parts
> demand?
> it
> simply
> screen.
> TIA,
> Paul Siebers
Paul,
What we do is also unrelease the job and unengineer the job. But we were having problems with people thinking someone made a mistake and forgot to check the box. So what we did under Schedule Priority - we created that states ON HOLD. We also created a bitmap -
which is very noticable that SAYS HOLD. - This seems to have helped us - but we do not put that many jobs on hold.
Hope this helps
Dina
Paul Siebers wrote:
> Hello all,
> demand?
> TIA,
> Paul Siebers
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
Jim,
Thanks for the input as it will become more important to us as we get
into live accounting in January.
Jim,
Another approach to solve this problem is to change the Description on
the job to state Job is on hold. That way anyone who might thing the
job was just accidentally UN-engineered will see the "JOB-ON-HOLD" note
in the job description. Also, all job status reports will clearly
reflect that the job is on hold.
Steve
Sent: Tuesday, December 05, 2000 11:09 AM
or material
into a
problems for
someone
has
sure we were
> From: Paul Siebers
> Hello all,
which a job
> can be
material
> and parts
> demand?
installed
> it
by
> simply
Entry
> screen.
> TIA,
> Paul Siebers
access/share Report
time you
password,
save the
Report
try it, go to
My Groups,
the link above
Is anyone using one of the check boxes to show that it is on hold? You can
set them up for different internal reasons. Use report builder for a listing
of jobs on hold. Definitely want to unrelease so no labor can be recorded
and so it is not on the job queues.
> Sent: Tuesday, December 05, 2000 10:44 AM
> Jim,
> Jim,
> Steve
> From: Jim Frice [SMTP:Jim.Frice@...]
> or material
> into a
> problems for
> someone
> has
> sure we were
> > From: Paul Siebers
> > Hello all,
> which a job
> > can be
> material
> > and parts
> > demand?
> installed
> > it
> by
> > simply
> Entry
> > screen.
> > TIA,
> > Paul Siebers
> access/share Report
> time you
> password,
> save the
> Report
> try it, go to
> My Groups,
> the link above
I think we are encountering the same problem that you guys did. Your
I have figured out I can create a new priority factor in the Scheduling
Priority Codes Maintenance field. The help menu doesn't tell me if I
can use 0 as a factor, which I would be inclined to use. If I can, does
it hold true that the job does no longer generate a demand on materials.
And can people still clock hours to a job on hold? I guess I will be
playing with my Vantage Test Box as well to get more insight in priority
codes...
Paul
Paul,
Hope this helps
Dina
Paul Siebers wrote:
> Hello all,
parts
> demand?
> TIA,
> Paul Siebers
Well, so much for that idea. I just figured out that the Priority Factor
can't be 0...
Sent: Wednesday, December 06, 2000 4:18 PM
codes...
Paul
Paul,
Hope this helps
Dina
Paul Siebers wrote:
> Hello all,
parts
> demand?
> TIA,
> Paul Siebers
Paul,
When you UN-engineer a job, there is no longer a demand for the
materials, the job cannot be scheduled, the job will be off all
schedules and priority dispatch reports and no data collection can
occur. We generally put jobs on hold for two reasons. One is the
occasional customer hold. The other is our need to do additional
structuring and/or make drawing changes. When purchase materials are
involved and we want to continue with the buy. We release the job long
enough for purchasing to print the purchase orders and then UN-engineer
it again.
Your
Vantage
What
Scheduling
if I
can, does
materials.
will be
priority
codes...
Paul
Paul,
But we
and
- we
helped us
Hope this helps
Dina
Paul Siebers wrote:
> Hello all,
job can be
and
parts
> demand?
installed it
simply
screen.
> TIA,
> Paul Siebers
Report
try it,
choose
password,
Files,
try it, go
choose My
password,
Thanks for the input, Steve...
However, we do things kind of weird here. I am the first one to admit
that and to suffer from it. The problem is that we need a way to place
jobs on hold in such a way that they do not generate a demand on
materials. However, we still have to be able to collect labor to these
jobs. I know it sounds bizar but a few times a month we have a job on
the floor where we are eg. working on a machine's frame in advance, but
the internals are still subject to change. Any suggestions are
welcome... At this point I am also forwarding the problem for review at
Epicor, maybe they can do some custom programming, since I really like
the idea of being able to select a "HOLD" option on the Scheduling
Priority-gauge on Job Entry.
Paul
Sent: Wednesday, December 06, 2000 4:42 PM
Paul,
it again.
Your
Vantage
What
Scheduling
if I
can, does
materials.
will be
priority
codes...
Paul
Paul,
But we
and
- we
helped us
Hope this helps
Dina
Paul Siebers wrote:
> Hello all,
job can be
and
parts
> demand?
installed it
simply
screen.
> TIA,
> Paul Siebers
Report
try it,
choose
password,
Files,
try it, go
choose My
password,
Paul,
To solve similar problems like you suggested, I leave the job engineered
and released, do a pull and drop on the job scheduling board to put the
assemblies, operations and linked materials out into the future. In
your case the operations and materials can be moved as you see fit by
which operation you link your materials. Start with two assembly
operations for the machine work, one on the machine's frame and the
later operation to work on the machine's internals out in the future.
As you determine what else you need for the internals, you can
UN-engineer the job long enough to add those materials. You can also
move and drop the scheduling so that your materials for the internals
become due just in time for you to begin the internals work.
Steve
Sent: Wednesday, December 06, 2000 5:07 PM
admit
place
to these
job on
advance, but
review at
really like
Scheduling
Paul
Paul,
can
the
additional
materials are
job long
UN-engineer
it again.
guys did.
Your
hoping
Vantage
implementing it.
What
operations?
the
Scheduling
tell me
if I
If I
can, does
demand on
materials.
guess I
will be
insight in
priority
codes...
Paul
[mailto:dhieber@...]
Paul,
job.
But we
mistake
and
Priority
- we
have
helped us
Hope this helps
Dina
Paul Siebers wrote:
> Hello all,
which a
job can be
material
and
parts
> demand?
installed it
hold by
simply
Job Entry
screen.
> TIA,
> Paul Siebers
access/share
Report
time you
try it,
password,
choose
save the
password,
access/share Report
Files,
time you
try it, go
password,
choose My
the
password,
access/share Report
time you
password,
save the
Files,
try it, go
choose My
password,
Paul,
Sorry I did not get back to you yesterday. Our ISP was down and I did not have access to mail.
Unfortuanately, when I put a job on hold - EVERYTHING on that job is on hold. Material, Labor etc... If we put on job on hold it is because the customer is making changes or engineering needs to make a change - Sorry I could not help any further.
Dina
> codes...
> Paul
> From: Dina Hieber [mailto:dhieber@...]
> Paul,
> Hope this helps
> Dina
> Paul Siebers wrote:
> > Hello all,
> parts
> > demand?
> > TIA,
> > Paul Siebers
