Pivot Help
I’m trying to pivot the ProdCal table and having a hard time figuring this out.
What I need is a table to join with the columns CalendarID, WeekDayNum, and True/false
So I need this.
To pivot to this.
I can’t figure out how I would get the field names into data in a row. The pivot function only takes data from the table (which makes sense, but doesn’t help me)
Anyone have an idea on how to do this?
Are you trying to pivot within the BAQ I am assuming?
That’s what I am trying to do. Looking at it now, I don’t know if the pivot function is the right tool for the job. I’m trying to see if I can get a CTE to work now buy looping through 1-7 and doing a calculated field with a case statement to grab correct field. I just really don’t understand CTE queries. I’ve gotten a couple of them to work before, but I don’t understand how/why some things work the way they do, so unless I have an explicit example, they never seem to work for me.
hahaha I feel you! It happens the same to me
I think I may have figured it out. (It still seems like trial and error to me) but I have a list of number and calendar ID’s so I should be able to make my calculated field.
This should work.
would you mind sharing how you did it? I am curious now as of how to accomplish it.
Here’s the BAQ. I’m on 10.2.200.8.
shiftpivot.baq (43.4 KB)
Here’s the SQL for those who can’t open it.
with [DayNumbers] as
(select
	[ProdCal].[Company] as [ProdCal_Company],
	[ProdCal].[CalendarID] as [ProdCal_CalendarID],
	(1) as [Calculated_DayNum]
from Erp.ProdCal as ProdCal
union all
select
	[ProdCal1].[Company] as [ProdCal1_Company],
	[ProdCal1].[CalendarID] as [ProdCal1_CalendarID],
	(DayNumbers.Calculated_DayNum + 1) as [Calculated_DayNum]
from  DayNumbers  as DayNumbers
inner join Erp.ProdCal as ProdCal1 on
	DayNumbers.ProdCal_CalendarID = ProdCal1.CalendarID
	and DayNumbers.ProdCal_Company = ProdCal1.Company
where DayNumbers.Calculated_DayNum <= 6)
select
	[DayNumbers1].[ProdCal_Company] as [ProdCal_Company],
	[DayNumbers1].[ProdCal_CalendarID] as [ProdCal_CalendarID],
	[DayNumbers1].[Calculated_DayNum] as [Calculated_DayNum],
	(case when DayNumbers1.Calculated_DayNum = 1 then ProdCal2.WorkWeek1
    when DayNumbers1.Calculated_DayNum = 2 then ProdCal2.WorkWeek2
    when DayNumbers1.Calculated_DayNum = 3 then ProdCal2.WorkWeek3
    when DayNumbers1.Calculated_DayNum = 4 then ProdCal2.WorkWeek4
    when DayNumbers1.Calculated_DayNum = 5 then ProdCal2.WorkWeek5
    when DayNumbers1.Calculated_DayNum = 6 then ProdCal2.WorkWeek6
    when DayNumbers1.Calculated_DayNum = 7 then ProdCal2.WorkWeek7
   else  0
 end) as [Calculated_ValidDay]
from  DayNumbers  as DayNumbers1
inner join Erp.ProdCal as ProdCal2 on
	DayNumbers1.ProdCal_Company = ProdCal2.Company
	and DayNumbers1.ProdCal_CalendarID = ProdCal2.CalendarID
Thanks!
