Pivoit or BAQ View is truncating field
I have a BAQ in which I am trying to retrieve a text value from the Configurator inputs view. Its truncating the value to the first 50 character, and I don’t know why. I have it set to far more than 50 is the display fields. Could it be the pivot or the fact that the data is coming from a view?
@Olga do you know if this is a limitation of the PcInputValue view ?
 * Disclaimer!!!
 * This is not a real query being executed, but a simplified version for general vision.
 * Executing it with any other tool may produce a different result.
select
	[JobHead].[ReqDueDate] as [JobHead_ReqDueDate],
	[JobHead].[JobNum] as [JobHead_JobNum],
	[Customer].[Name] as [Customer_Name],
	[JobHead].[PartDescription] as [JobHead_PartDescription],
	[JobHead].[ProdQty] as [JobHead_ProdQty],
	[JobMtl].[PartNum] as [JobMtl_PartNum],
	[JobMtl].[Description] as [JobMtl_Description],
	[ConfigData].[ISBLength] as [ConfigData_ISBLength],
	[ConfigData].[LapSelection] as [ConfigData_LapSelection],
	[ConfigData].[StripDisplay] as [ConfigData_StripDisplay],
	(LEN(ConfigData.StripDisplay)) as [Calculated_length]
from Erp.JobHead as JobHead
inner join Erp.JobProd as JobProd on
	JobHead.Company = JobProd.Company
	and JobHead.JobNum = JobProd.JobNum
inner join Erp.OrderDtl as OrderDtl on
	JobProd.Company = OrderDtl.Company
	and JobProd.OrderNum = OrderDtl.OrderNum
	and JobProd.OrderLine = OrderDtl.OrderLine
	and ( OrderDtl.OpenLine = 1  )
left outer join  (select
	[PcInputValue].[InputName] as [PcInputValue_InputName],
	[PcInputValue].[InputValue] as [PcInputValue_InputValue],
	[PcInputValue].[RelatedToSysRowID] as [PcInputValue_RelatedToSysRowID]
from Erp.PcInputValue as PcInputValue)  ConfigData_src
pivot
(max(PcInputValue_InputValue)
for  PcInputValue_InputName in ('ISBLength', 'LapSelection', 'StripDisplay')  )
 as ConfigData on
	OrderDtl.SysRowID = ConfigData.PcInputValue_RelatedToSysRowID
inner join Erp.Customer as Customer on
	OrderDtl.Company = Customer.Company
	and OrderDtl.CustNum = Customer.CustNum
left outer join Erp.QuoteDtl as QuoteDtl on
	OrderDtl.Company = QuoteDtl.Company
	and OrderDtl.QuoteNum = QuoteDtl.QuoteNum
	and OrderDtl.QuoteLine = QuoteDtl.QuoteLine
left outer join Erp.JobMtl as JobMtl on
	JobHead.Company = JobMtl.Company
	and JobHead.JobNum = JobMtl.JobNum
	and ( JobMtl.Description like '%lap%'  )
where (JobHead.ProdCode = 'Piano'  and JobHead.QtyCompleted < JobHead.ProdQty)
This is it right here. I don’t know if this is a function of views in general, or if it’s just this table, but the PcInputValue view only contains the first 50 characters of the actual Configurator Input Value.
Characters GIF
darn…
