Pictures in methods
Ideally what you'd have in the Crystal programming model is an event like OnBeforePrint() and OnAfterPrint(). If I had the path references to the PDF files then I could just call the Acrobat Print action on the PDF file and it would print automatically. E.g.
set oWsh = CreateObject ("Wscript.Shell")
oWsh.run """Acrobat.exe"" /p /h" &FileName,,true
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charlie Wilson
Sent: Friday, October 09, 2009 8:28 AM
Subject: RE: [Vantage] Re: Pictures in methods
The logic makes sense I guess. I kinda wish they wouldn't protect me from
myself and let me figure that out.
I've been digging to google results this morning and it doesn't seem too
many people want to embed "dynamic" pdfs into a crystal that are pulled from
a location held in a field.
~Charlie
_____
Gerry Loranger
Sent: Friday, October 09, 2009 8:21 AM
I checked into this. Link a doc, pdf etc and Crystal runs a process that
creates an image and embeds it into the report. You'll notice that when you
link to a large PDF or Doc, Crystal seems to hang for a bit? The image
creation process can take quite some time, depending on the size of the PDF,
Doc etc. If Crystal allowed PDFs and Docs to be linked to files, this image
creation process might have to run on numerous records - resulting in a
major crashing issue.
Perhaps, there is a way to script Crystal and override this safety
feature... but that would be far too ambitious to attempt on a Friday.
Gerry
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
Charlie Wilson
Sent: Friday, October 09, 2009 6:30 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
We ultimately want them on the job traveler. The engineer that asked for
this may be willing to deal with the limitation of it needing to be a
JPG/BPM/TIF file. Rebuilding the job traveler as a dashboard doesn't sound
like a lot of fun.
He can just scan what ever he want to jpg and attach it that way.
~Charlie
_____
<mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Rob Bucek
Sent: Thursday, October 08, 2009 4:57 PM
Charlie,
Can this report be done in a dashboard instead? I have gotten dynamic
url linking to work in dashboards before using file paths from a user
defined field in a table or what have you. The image (.pdf, .jpg etc)
displays on a tab/sheet. You could print it from there.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg <http://www.dsmfg <http://www.dsmfg.com/> com/> com/>
(Click the logo to view our site) <http://www.dsmfg <http://www.dsmfg
com/>
Behalf
Of Charlie Wilson
Sent: Thursday, October 08, 2009 3:30 PM
Didn't really get me anywhere.
~Charlie
_____
Behalf Of
Mark Wonsil
Sent: Thursday, October 08, 2009 4:10 PM
> Then on your Crystal report, Insert > OLE Object > Create
> from File. Select any image and click OK.
Sounds like it's embedding the OLE object. What happens if you click the
"Link" checkbox at this step?
Mark W.
We would love to include pictures and diagrams in our methods to help
explain what people should be doing does anyone know of a way to do this?
~Charlie
Do you have Document Association; attachments
Charlie Wilson
Sent: Thursday, October 08, 2009 9:38 AM
Subject: [Vantage] Pictures in methods
~Charlie
The following bit of code loads an embedded image, specified in a user
defined character field, in a picturebox control on the part form:
Private Sub PartForm_Load(ByVal sender As object, ByVal args As
EventArgs) Handles PartForm.Load
'// Add Event Handler Code
Dim fileName As String = String.Empty
Dim companyAdapter As CompanyAdapter = New
CompanyAdapter(EngWorkBenchEntryForm)
companyAdapter.BOConnect()
Dim company As String = PartForm.Session.CompanyID
Dim found As Boolean = companyAdapter.GetByID(company)
if (found) then
fileName =
companyAdapter.CompanyData.Company.Rows(0)("Character10")
picPartAttachment.Image =
System.Drawing.Image.FromFile(fileName)
end if
End Sub
This got put on the back burner, I still haven't had a chance to test it.
Gerry
Charlie Wilson
~Charlie
Yes we can attach outside documents to internal vantage documents such as a
part master.
But how can we get it to display on the method that we print off and send
out to the floor?
~Charlie
_____
advantage@...
Sent: Thursday, October 08, 2009 9:44 AM
Subject: RE: [Vantage] Pictures in methods
Behalf Of
Charlie Wilson
~Charlie
Here's a suggestion.
Utilize a user character field to store the image locations.
Then on your Crystal report, Insert > OLE Object > Create from File. Select any image and click OK.
Position the image on your Crystal Report.
Right click over the image and select Format Graphic, select the Picture tab and then click the Graphic Location tab.
Enter the image file location, field.
I would think the images should be a standard size or your report could get messy.
Gerry
> part master.
> out to the floor?
> ~Charlie
> _____
> advantage@...
> Behalf Of
> Charlie Wilson
> ~Charlie
Now that is pretty slick time to hit the drawing board with this one.
~Charlie
_____
schmangy20000
Sent: Thursday, October 08, 2009 10:33 AM
Subject: [Vantage] Re: Pictures in methods
messy.
Gerry
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Charlie
a
> part master.
> out to the floor?
> ~Charlie
> _____
Behalf Of
> advantage@...
> Behalf Of
> Charlie Wilson
> ~Charlie
Any way I could make It do PDFs DOCs and XLSs files?
~Charlie
_____
schmangy20000
messy.
Gerry
a
> part master.
> out to the floor?
> ~Charlie
> _____
Behalf Of
> advantage@...
> Behalf Of
> Charlie Wilson
> ~Charlie
You can link any file in Crystal using the same method.
Charlie Wilson
Sent: Thursday, October 08, 2009 11:52 AM
~Charlie
_____
Behalf Of
schmangy20000
messy.
Gerry
a
> part master.
> out to the floor?
> ~Charlie
> _____
Behalf Of
> advantage@...
> Behalf Of
> Charlie Wilson
> ~Charlie
When I use your method I can import an intial PDF for example but after I
make the change to the graphic file location it doesn't change.
~Charlie
_____
Gerry Loranger
Sent: Thursday, October 08, 2009 1:08 PM
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
schmangy20000
messy.
Gerry
a
> part master.
> out to the floor?
> ~Charlie
> _____
Behalf Of
> advantage@...
> Behalf Of
> Charlie Wilson
> ~Charlie
I'm seeing the same thing with PDFs and docs.
Charlie Wilson
Sent: Thursday, October 08, 2009 1:17 PM
~Charlie
_____
Behalf Of
Gerry Loranger
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
schmangy20000
messy.
Gerry
a
> part master.
> out to the floor?
> ~Charlie
> _____
Behalf Of
> advantage@...
> Behalf Of
> Charlie Wilson
> ~Charlie
If you change to a picture it does change doesn't it?
It's almost like if it is some file type other than an image it needs to be
entered somewhere else.
I wish I could select my datafield at the location that you browse for the
initial file.
~Charlie
_____
Gerry Loranger
Sent: Thursday, October 08, 2009 1:47 PM
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Gerry Loranger
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
schmangy20000
messy.
Gerry
a
> part master.
> out to the floor?
> ~Charlie
> _____
Behalf Of
> advantage@...
> Behalf Of
> Charlie Wilson
> ~Charlie
Yes, images are displaying the file specified but pdfs only display the
original file. If I get a chance to look into it and get pdfs working, I'll
let you know. If you get it going, I'd be interested in knowing the
resolution.
Charlie Wilson
Sent: Thursday, October 08, 2009 1:53 PM
initial file.
~Charlie
_____
Behalf Of
Gerry Loranger
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Gerry Loranger
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
schmangy20000
messy.
Gerry
a
> part master.
> out to the floor?
> ~Charlie
> _____
Behalf Of
> advantage@...
> Behalf Of
> Charlie Wilson
> ~Charlie
Mark W.
~Charlie
_____
Mark Wonsil
Mark W.
Which means you still get a static pdf, doc, etc.?
yes
~Charlie
_____
Mark Wonsil
Sent: Thursday, October 08, 2009 4:46 PM
Charlie,
Rob Bucek
FAX: (715)284-4084
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Charlie Wilson
~Charlie
_____
Behalf Of
Mark Wonsil
Mark W.
like a lot of fun.
~Charlie
_____
Rob Bucek
Charlie,
Rob Bucek
FAX: (715)284-4084
(Click the logo to view our site) <http://www.dsmfg <http://www.dsmfg.com/>
com/>
Behalf
Of Charlie Wilson
~Charlie
_____
Behalf Of
Mark Wonsil
Mark W.
Gerry
Charlie Wilson
like a lot of fun.
~Charlie
_____
Behalf Of
Rob Bucek
Charlie,
Rob Bucek
FAX: (715)284-4084
com/>
Behalf
Of Charlie Wilson
~Charlie
_____
Behalf Of
Mark Wonsil
Mark W.
