Hi All...
Been gearing up for year end physical inventory here. Found a few
glitches & fixes in the tag print program (actually the Crystal form) that
might help ya' get an easier and more accurate count.
1) The part description only prints 30 characters. We depend on the full
description to accurately identify many of our parts. The data in the .DBF
file is actually a memo field with the whole description. If you change
the field to "can grow" in Crystal, and widen it you can get it all on your
tags.
2) No unit of measure prints. How the !@#$ did Epicor miss this
one? Brute force work around: Use export utility to export entire Part
table to DBase file with IUM. Import to Access, create index / primary key
on Part. Save as .MDB file. Join with CountTag in Crystal. Kind of a
kludge, but well worth the effort.
Anyone have any words of wisdom for someone running this in Vantage for the
first time? (I have a couple saved from earlier this month)
-Thanks,
Wayne Cox
tags.
-Thanks,
Wayne Cox
