Phantom BOM
Previously created BOM no longer function as phantoms when we did our
conversion from Vantage 5.2 to Vantage 8.03. For example when the "Pull
as Assembly" box is no longer checked when a part number from vantage
5.2 is added to a BOM. New part numbers can be created as phantoms and
function properly. Any ideas hoe this can be fixed?
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Phone: 920-898-1560 Ext.152
Cell: 920-960-0062
Email: tlate@... <mailto:tlate@...>
I'm trying to use a Phantom BOM in a job and when I get details I get this
error. "The JobAsmbl record has NO-LOCK status. Delete Not Allowed(335)".
Does anyone know what this is? Vantage 5.0
Fredy Venczel
Has anyone used the Phantom BOM. If yes could you give a basic
example of how and why you are using it. Also the Phantom BOM
checkbox is grayed out on my screen. Is this an access issue or an
additional module issue.
Pat Maher
Espey Mfg & Electronics
Pat,
I am not using the Phantom Bom at the moment but your box is grayed out
because you have the part set up as stock. It has to be non-stock.
Fredy Venczel
Sent: Tuesday, May 04, 2004 11:19 AM
Subject: [Vantage] Phantom BOM
Pat Maher
I love the phantom BOM. What this does is help satisfy the wants/needs of both engineering and production.
Engineering wants things grouped together for release, but production doesn't want a huge list of assemblies to scroll through - they only want the parts. Phantom boms are for assemblies (manufactured) only and not parts that are purchased directly (that is why it is grayed out). They let you group purchased parts together for release to job entry.
The difference is when you add a phantom BOM to job entry and get details on it, the "assembly" line will be deleted and will leave the "materials" behind.
Example: Assembly 0 is the top-level assembly. Assembly 1 is a phantom BOM you just added. When you get details on it, assembly 1 will be deleted and it's children will become materials to assembly 0.
Does this make sense?
Eric L. Tyira
Software Engineer
Tamglass Tempering Systems, Inc.
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
Pat Maher
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=129n0emj0/M=295196.4901138.6052515.3001176/D=groups/S=1705007183:HM/EXP=1083770384/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6052515.3001176/D=groups/S=:HM/A=2128215/rand=908451809>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of <http://docs.yahoo.com/info/terms/> Service.
Thanks ALL,
This will do exactly what I need. Its very interesting during my
testing I found that if you have operations in the highest level
assembly and you link a phantom BOM assembly below it and that
assembly was attached to a particular operation the result is a top
level assembly with perfectly aligned operations based on the initial
setup. Material is also linked properly.
You just prevented a huge fight between Engineering and Production.
Thanks again
Pat Maher
--- In vantage@yahoogroups.com, "Ordway, Bruce" <bruceo@b...> wrote:
> Hi Eric,
> >Does this make sense?<
> Yes this is how I have found Phantoms to work.
> The fact that the number for the phantom disappears in the parent
assembly is a little unnerving for me.
> We have gigantic BOM's & maintainance is already a complicated
chore.
> Having parts on the BOM & not knowing what structure they came from
seems like trouble.
> If you are doing maintenance on a BOM that contains a component
that came from a phantom, how do you trace back to that phantom?
> Thanks,
> Bruce Ordway
> Viking Engineering
> bruceo@v...
> Eric L. Tyira
> Software Engineer
> P: (856) 786-1200
> F: (856) 786-7606
> eric.tyira@t...
> From: plmaher2001 [mailto:plmaher2001@y...]
> Thanks
> Pat Maher
access. )
> ADVERTISEMENT
09>
> _____
> Yahoo! Groups Links
> ------------------------ Yahoo! Groups Sponsor ---------------------
> Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or
Lexmark
> Printer at MyInks.com. Free s/h on orders $50 or more to the US &
Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/PhFolB/TM
access. )
> Yahoo! Groups Links
Most of the time I don't care where it came from. Probably 95%+ of our assemblies are NOT phantom boms. But if you did want to trace it back, you can just call it up in part maintenance or part tracker and do a "where used". This will them list all the boms the part is called in, including the phantom one.
At first, I was nervous too. "Deleting a sub-assembly, you can't do that!" But like anything else you get used to it.
Eric L. Tyira
Software Engineer
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
Sent: Tuesday, May 04, 2004 1:11 PM
Subject: [Vantage] Re: Phantom BOM
Thanks ALL,
Thanks again
Pat Maher
> Hi Eric,
chore.
seems like trouble.
> Thanks,
> Bruce Ordway
> Viking Engineering
> bruceo@v...
> Eric L. Tyira
> Software Engineer
> P: (856) 786-1200
> F: (856) 786-7606
> eric.tyira@t...
> Thanks
> Pat Maher
access. )
> ADVERTISEMENT
< http://rd.yahoo.com/SIG=129n0emj0/M=295196.4901138.6052515.3001176/D=
> < http://us.adserver.yahoo.com/l?
09>
> _____
> Yahoo! Groups Links
of < http://docs.yahoo.com/info/terms/> Service.
Lexmark
Canada.
access. )
> Yahoo! Groups Links
ADVERTISEMENT
<http://rd.yahoo.com/SIG=129lg4n79/M=295196.4901138.6052515.3001176/D=groups/S=1705007183:HM/EXP=1083777091/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6052515.3001176/D=groups/S=:HM/A=2128215/rand=282287444>
_____
Yahoo! Groups Links
I think the way I look at it is a phantom BOM does not have to be a "real" BOM. It's just a way for engineering to group parts together and release them with a few keystrokes. It can even have a B.S. part number and name. I would also suggest using a Phantom BOM for rock solid designs that have no chance of generating problems.
Example 1 (solid design): We need to release chain tensioners. They consist of a base, shaft and sprocket each ordered and stocked individually. There are #40 single, #50 single, double and triple, and timing belt each with a fixed base, adjustable with teeth and adjustable with teeth and a slotted base. We have setup a drawing that shows all the combinations of tensioners. Each drawing number of the tensioners (12345-001, 12345-002, 12345-003, etc.) is a phantom assembly in Vantage. The tensioner assembly is called in the drive assembly as view as assembly, pull as assembly. The drive assembly DOES NOT call the tensioner materials directly as this would result in duplication. When we release the drive assembly, the phantom collapses and leaves the tensioner materials behind in the drive assembly. The drive assembly drawing shows which tensioner assembly goes where. If production wants the tensioner assembly drawing, they can get a copy using the drive assembly drawing as the reference to the tensioner drawing number. In this example we are able to trace the materials to the phantom BOM and cross reference the assembly drawing using another assembly drawing. And yes, the BOM in job entry does not exactly match the BOM on the drawing ... but it is acceptable for us.
Example 2 (bs part number): I need to release rigidizer and coating cement for our insulation. For every gallon of coating cement, there is a quarter gallon of rigidizer needed. We have setup a B.S. phantom BOM that calls for 1 gallon of coating cement and .25 gallons of rigidizer per parent. When we add this assembly to job entry, we call for a quantity of 100, then get details. The assembly is deleted and the coating cement and rigidizer are left behind in the insulation assembly as materials with, you got it, 100 gallons of coating cement and 25 gallons of rigidizer. In this example, I don't care where it came from, only if the quantity (and ratio for future releases) is correct.
I know at least here, as long as production gets the parts, they can build it. Our production is not interested in highly complex, indented assemblies with confusing travelers. In the end, it's just a list of parts in job entry and the travelers are simplified.
Oh, and I would suggest that if you do use phantom boms, put the word "phantom" in the description so you can find them all quickly in part maintenance.
Eric L. Tyira
Software Engineer
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
Sent: Tuesday, May 04, 2004 9:12 PM
Subject: RE: [Vantage] Re: Phantom BOM
Eric,
>I don't care where it came from.<
> ...a "where used". This will them list all the boms the part is
called in, including the phantom.<
Please check this out & let me know if it's right.
Part A is on BOM 123 because Phantom ABC was added to the BOM.
A where used shows Part A used on BOM 123 and Phantom ABC.
Engineering says Part A has to change from Qty 1 to Qty 2.
I think you have to update BOM 123 and Phantom ABC as separate entities
now.
It appears to me that if using phantoms you end up with double the
maintenance?
How do you handle ECO's when phantoms are involved?
I like the idea of phantoms but not having a reference on the parent BOM
seems like it will cause problems in our environment. Let me know if you
have this covered somehow.
I've used another system with a different style of phantom. It kept the
reference to the phantom in the parent BOM. That way, update the
phantom, the parent BOM is updated at the same time.
The Vantage style phantom has me balking.
Bruce Ordway
Viking Engineering
ADVERTISEMENT
<http://rd.yahoo.com/SIG=129kinrua/M=295196.4901138.6052515.3001176/D=groups/S=1705007183:HM/EXP=1083805909/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6052515.3001176/D=groups/S=:HM/A=2128215/rand=157077240>
_____
Yahoo! Groups Links
Bruce if you would look in Vantage help there is a good example of a Phantom
BOM. It is pretty much the same thing as Eric just explained. I also had the
same question as you about the tracking/maintenance. If you look at the
routing of a BOM it looks like there is a subassembly and really there
isn't. As Eric suggested put "phantom" in the description or as someone
suggested to me, put a specific prefix in the part number to specify it's a
phantom.
Fredy Venczel
Sent: Wednesday, May 05, 2004 7:58 AM
they ca n get a copy using the drive assembly drawing as the reference to
maintenance.
Eric L. Tyira
Software Engineer
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
Eric,
entities
now.
maintenance?
BOM
you
the
Bruce Ordway
Viking Engineering
Anyone out there have a procedure for setting up a phantom BOM? I am
trying to set up a part as a phantom BOM (non-stock assy) in order to
relieve the raw parts from inventory and cannot seem to make it work on
a job.
Phantoms will not work with Kanban receipts at least in 6.1.
Of pa.berglund
Sent: Friday, July 21, 2006 1:18 PM
a job.
what version ? we are on Vantage 8.0 and have no issues in using phantom BOM
, though there is a bug in costing module till 805f
vishal
>From: "Frank Zeigafuse" <frankz@...>
>Reply-To: vantage@yahoogroups.com
>To: <vantage@yahoogroups.com>
>Subject: RE: [Vantage] Phantom BOM
>Date: Sat, 22 Jul 2006 17:06:35 -0400
>Of pa.berglund
>a job.
We use a Phantom BOM as part of configurating a part number.
Therefore our use of Phantoms might be different then yours. That
being said, we would suggest the following:
1 - The 808E patch fixed a number of issues relating to phantom use
in the configurator. Maybe this would "spill over" to phantom's in
general.
2 - Are you using a revision level on the BOM? Without a revision
level our phantom did not work correctly.
3- Install Open Edge Service Pack 5. Configurator (with phantom)
works much better then when we were running Opene Edge Service Pack
3.
phantom BOM
> vishal
Behalf
> >Of pa.berglund
am
order to
work on
> >a job.
Make sure that you specify the assembly to be 'phantomised' as both
non-stocked and as a phantom.
Make sure that this assembly is set to be "Pull As Assy" in it's parent BOM.
When you raise a job for the parent, the operations will consist of
operations from the phantom followed by operations from the parent.
Similarly the materials will contain the material demand from both the
phantom and the parent.
It works fine for us on 6.10.
HTH
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Tel: +44(0)1253 738311
Mob: +44(0)7836 550360
Fax: +44(0)870 7628173
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
pa.berglund
Sent: 21 July 2006 18:18
a job.
Do you use kanban receipts?
Of Vishal Mehta
Sent: Saturday, July 22, 2006 6:07 PM
BOM
vishal
<mailto:frankz%40lcdarms.com> >
>Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
>From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Behalf
>Of pa.berglund
>a job.
