Perform Click of Clear Tool with code
As always, thanks Jose. Worked like a charm.
Sent: Tuesday, June 19, 2012 9:59 AM
Subject: Re: [Vantage] Perform Click of Clear Tool with code
on 9.05XX
ADd
using System.Reflection;
On Button Click'
private void epiButtonC1_Click(object sender, System.EventArgs args)
MethodInfo mi =
typeof(Epicor.Mfg.UI.App.IssueMaterialEntry.IssueMaterialForm).GetMethod("OnClickClear",
BindingFlags.NonPublic | BindingFlags.Instance);
mi.Invoke(IssueMaterialForm, new object[] { });
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
On Tue, Jun 19, 2012 at 9:54 AM, Rob Bucek <rbucek@...> wrote:
> This would be for 8.03...
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> [Description: cid:1.234354861@...]<
> http://www.dsmfg.com/>
> (Click the logo to view our site)<http://www.dsmfg.com/>
> Of Rob Bucek
> Sent: Tuesday, June 19, 2012 8:54 AM
> Subject: RE: [Vantage] Perform Click of Clear Tool with code
> Here is some code that I use to suppress some buttons on a tool bar..this
> should get you close...
> Imports Infragistics.Win.UltraWinToolBars
> Module Script
> Dim baseToolbarsManager As
> Infragistics.Win.UltraWinToolbars.UltraToolbarsManager
> Sub InitializCustomCode()
> dim obj as Object =
> GetType(Epicor.Mfg.UI.App.UD11Entry.UD11Form).InvokeMember("baseToolbarsManager",
> BindingFlags.Instance Or BindingFlags.GetField Or BindingFlags.NonPublic,
> Nothing, UD11Form, Nothing)
> BaseToolbarsManager =
> ctype(obj,Infragistics.Win.UltraWinToolbars.UltraToolbarsManager)
> HideTools()
> Sub HideTools()
> if BaseToolBarsManager.Tools.Exists("NewTool")
> BaseToolBarsManager.Tools("NewTool").SharedProps.Enabled = False
> end if
> if BaseToolBarsManager.Tools.Exists("SaveTool")
> BaseToolBarsManager.Tools("SaveTool").SharedProps.Enabled = false
> end if
> End Sub
> Rob Bucek
> FAX: (715)284-4084
> [Description: cid:1.234354861@...<mailto:
> 1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> tkoch77
> Sent: Tuesday, June 19, 2012 8:37 AM
> Subject: [Vantage] Perform Click of Clear Tool with code
> Anyone have an example on how to click a toolbar button with code? Trying
> to clear the form after a user clicks on a button, oTrans.Clear() isnt
> working.
> Thanks,
> Ted
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Anyone have an example on how to click a toolbar button with code? Trying to clear the form after a user clicks on a button, oTrans.Clear() isnt working.
Ted
Which form?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> working.
> Thanks,
> Ted
Issue Material
Sent: Tuesday, June 19, 2012 9:41 AM
Which form?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> working.
> Thanks,
> Ted
What version? 8x? 9x? 9.05X?
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Jun 19, 2012 at 9:49 AM, Ted Koch <tkoch77@...> wrote:
> Issue Material
> From: Jose Gomez <jose@...>
> Which form?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > working.
> > Thanks,
> > Ted
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
Sorry, 9.05.607B
Sent: Tuesday, June 19, 2012 9:50 AM
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Issue Material
> Which form?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
>Â <http://www.google.com/profiles/jose.gomez> <
>Â <http://www.josecgomez.com/professional-resume/>
>Â <http://www.usdoingstuff.com>
> > working.
> > Thanks,
> > Ted
Here is some code that I use to suppress some buttons on a tool bar..this should get you close...
Module Script
Dim baseToolbarsManager As Infragistics.Win.UltraWinToolbars.UltraToolbarsManager
dim obj as Object = GetType(Epicor.Mfg.UI.App.UD11Entry.UD11Form).InvokeMember("baseToolbarsManager", BindingFlags.Instance Or BindingFlags.GetField Or BindingFlags.NonPublic, Nothing, UD11Form, Nothing)
BaseToolbarsManager = ctype(obj,Infragistics.Win.UltraWinToolbars.UltraToolbarsManager)
HideTools()
Sub HideTools()
end if
end if
End Sub
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of tkoch77
Ted
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
Module Script
HideTools()
Sub HideTools()
end if
end if
End Sub
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of tkoch77
Ted
on 9.05XX
ADd
On Button Click'
MethodInfo mi =
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Rob Bucek
> FAX: (715)284-4084
> Of Rob Bucek
> Module Script
> dim obj as Object =
> HideTools()
> Sub HideTools()
> end if
> end if
> End Sub
> Rob Bucek
> FAX: (715)284-4084
> tkoch77
> working.
> Thanks,
> Ted
