I forgot the step about adding the appropriate labor expense code to the
employee master. This gives you the default expense code for a given
employee. This code will be overridden by any labor expense codes put on a
job. We use this functionality to send the labor dollars for a normally
indirect employee to a direct g/l account when he is working directly on a
job rather than in his normal indirect capacity. Seems like I remember
other cases where the labor expense code on an employee file can be
overridden, but it has been too long since we set this up for me to remember
now.
Nora Story
Spectra Technologies, Inc.
Subject: RE: [Vantage] Payroll Question
You can accomplish this with different labor expense codes under a given pay
type. Each expense code under a given pay type can have it's own G/L
account. For example, under a pay type for overtime, you could add direct,
G&A, & sales labor expense codes. Then update each of those codes to have
their own G/L account.
Nora Story
now.
Nora Story
Nora Story
