Can someone help me understand how the Payroll Date and Clock In Date on the LaborHed table show and earlier time/date than the corresponding JobCreate Date?
You can put in time for whenever you want in T&E. MES is the only place that records based on the current time. And the MES entries can be modified to have different times as well.
I am guessing this was caused by the employee clocking in the day before the job was created, never clocking off, and then Starting Activity on the job once it was available the next day / week or whatever. I believe that would give you a LaborHed date from the initial clock-in date which would be earlier than the Job create date.
Thanks Dan. That was the only conclusion I could come up with as well since the times were not manually edited.
