Password in clear text (Kinetic 2022.1)
Dear All,
I have installed Kinetic (Kinetic 2022.1) and configured with SQL Authentication Mode in Database Connection and Reporting Services.
When I checked Host.config (Connection string Section) (C:\inetpub\wwwroot\Kinetic_1\Server), found password is showing in clear text.
Regards,
Sanjeev Gupta
Yeah… it’s a connection string
Its in web.config not Host.config. You can always change your settings to use Windows Authentication.
Yes, Windows Authentication will be good.
Windows authentication is fine
There is an Epicor Ideas suggestion to have Epicor implement Secrets Management. In addition to improving security, it would make DevOps much easier. Here are some of the places where Kinetic ERP requires secrets:
  • Task Agent: credentials
  • Command Line Utilities: credentials in XML templates (DatabaseIUser, ServiceUser, EpicorUser, ApplicationPoolUser, SSRSDataBaseUser, RemoteUser, …)
  • SQL Server: credentials for sql users
  • Collaborate: Recovery Key
  • Application Pools: credentials
  • Automatic Login Stations like MES: credentials
  • Application Server: domain credentials
  • Admin Console: credentials for admin users
  • SMTP Server: credentials
  • Bartender: REST credentials
  • Enterprise Search: credentials
  • Data Discovery: credentials
  • Classic Web Access: credentials
  • IoT: Azure Managed Service Principals
  • Solution Workbench: command line credentials
  • Certificates: credentials
  • AFR Monitor: credentials
