I’ve got the LFO set up correctly on the program and I believe that it is passing along the correct data. I put two message boxes in just to be sure. However, when the report opens nothing is passed into it. I am trying to figure out what code is needed to handle the incoming information from the LFO. I have gone over these forum posts and had no success.
--------------------------------Code for MES Customization--------------------------------------
// Custom code for MESMenu
// Created: 11/21/2019 9:46:44 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win;
using Ice.Core;
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
private EpiDataView edvEmpBasic;
EpiButton btnDash;
this.edvEmpBasic = ((EpiDataView)(this.oTrans.EpiDataViews["EmpBasic"]));
this.edvEmpBasic.EpiViewNotification += new EpiViewNotification(this.edvEmpBasic_EpiViewNotification);
btnDash = (EpiButton)csm.GetNativeControlReference("fe187107-b719-4a3d-96a8-5f8505ea65ae");
this.btnDash.Click += new System.EventHandler(this.btnDash_Click);
this.edvEmpBasic.EpiViewNotification -= new EpiViewNotification(this.edvEmpBasic_EpiViewNotification);
this.edvEmpBasic = null;
// Begin Custom Code Disposal
// End Custom Code Disposal
this.btnDash.Click -= new System.EventHandler(this.btnDash_Click);
private void MESMenu_Load(object sender, EventArgs args)
// Add Event Handler Code
btnDash.ReadOnly = false;
private void btnDash_Click(object sender, System.EventArgs args)
string yourEMP;
yourEMP = ((Session)oTrans.Session).EmployeeID;
MessageBox.Show(yourEMP);
LaunchFormOptions lfo = new LaunchFormOptions();
lfo.ValueIn = yourEMP;
MessageBox.Show(lfo.ValueIn.ToString());
ProcessCaller.LaunchForm(oTrans, "UDLBRBAQ", lfo);
//ProcessCaller.LaunchForm(this.oTrans, "UDLBRBAQ");
private void edvEmpBasic_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
// view.dataView[args.Row]["FieldName"]
// args.Row, args.Column, args.Sender, args.NotifyType
// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
if ((args.NotifyType == EpiTransaction.NotifyType.Initialize))
if ((args.Row > -1))
EnableDisableCustomControls(true);
else
EnableDisableCustomControls(false);
private void EnableDisableCustomControls(bool iFlag)
btnDash.Enabled = iFlag;
----------------------------------------End Code for MES-----------------------------------------------------------
----------------------------------------My Attempt at handling the info passed on------------------------------
// Custom code for BAQReportForm
// Created: 11/22/2019 12:17:43 PM
using System;
using System.Data;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
public class Script
EpiDataView edvReportParam;
//DataSet ds = (DataSet)((Dictionary<string,DataSet>)oTrans.GetType().GetField(“filterDataSets”, BindingFlags.Public | BindingFlags.Instance | BindingFlags.NonPublic).GetValue(oTrans))[“FilterList2”];
EpiDataView edv = oTrans.Factory(“yourEMP”);
edvReportParam = oTrans.Factory("ReportParam.field3");
-----------------------------------------------End Attempt-----------------------------------------------------
Thanks for the help!
