Pass variables from dashboard to Job Receive Salvage using context menu
Dear Team,
I’m tried to bind the values on Job Number and Qty from dashboard using process caller (Launch Options) but I’m able to pass the values, but not able binding in the view. Kindly, Help me.
The below codes are used for pass and retrieve.
The values are passed from Dashboard to Job Receive Salvage on button click event. I’m able to pass the values, but not able to values are bind in epiview[“PartTran”] job number field on the Job Receive Salvage screen
Dashboard button click:
private void btnRcvSalvageQty_Click(object sender, System.EventArgs args)
EpiUltraGrid mesGrid;
mesGrid = (EpiUltraGrid)csm.GetNativeControlReference(“863b4eab-4334-4673-82b8-b9e73c64e59f”);
UltraGridRow ultraGridRow = mesGrid.ActiveRow;
	Qty = Convert.ToInt32(ultraGridRow.GetCellValue("Calculated_NetWeight"));
	JobNumber = ultraGridRow.GetCellValue("SerialNo_JobNum").ToString();
	LaunchFormOptions opts = new LaunchFormOptions();
	opts.IsModal = true;
	opts.ContextValue = ((Convert.ToInt32(Qty)) + "~" + Convert.ToString(JobNumber));
    ProcessCaller.LaunchForm(oTrans,"IMGO3019",opts);
The below code for try to bind the Job Number and Qty in Job Receive Salvage
// Custom code for RcptToSalForm
// Created: 15/12/2020 13:18:27
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
private EpiDataView edvPartTran;
private decimal Qty = 0;
private string JobNumber = string.Empty;
	this.edvPartTran = ((EpiDataView)(this.oTrans.EpiDataViews["PartTran"]));
	this.edvPartTran.EpiViewNotification += new EpiViewNotification(this.edvPartTran_EpiViewNotification);
	this.edvPartTran.EpiViewNotification -= new EpiViewNotification(this.edvPartTran_EpiViewNotification);
	this.edvPartTran = null;
	// Begin Custom Code Disposal
	// End Custom Code Disposal
private void RcptToSalForm_Load(object sender, EventArgs args)
	//string PartNumber = string.Empty;
	// Add Event Handler Code
	/*if(RcptToSalForm.LaunchFormOptions !=null)
    	EpiDataView edvCustomView = (EpiDataView)RcptToSalForm.LaunchFormOptions.ContextValue;
    	if(edvCustomView !=null)
			string Param = RcptToSalForm.LaunchFormOptions.ContextValue.ToString();
			char[] delimiterChars = {'~'};
			string[] SplitParam = Param.Split(delimiterChars);
			if (SplitParam.Length != 0)
				MessageBox.Show("2");
				MessageBox.Show("Part Number - " + Convert.ToString(SplitParam[0]));
				MessageBox.Show("Job Number - " + Convert.ToString(SplitParam[1]));
				PartNumber = Convert.ToString(SplitParam[0]);
				JobNumber = Convert.ToString(SplitParam[1]);
				edvCustomView.dataView[edvCustomView.Row]["PartNum"] = "001";
				edvCustomView.dataView[edvCustomView.Row]["JobNum"] = "002";
	if (RcptToSalForm.LaunchFormOptions != null)
		MessageBox.Show("1");
		if(SplitParam != null)
			MessageBox.Show(SplitParam[0].ToString());
			MessageBox.Show(SplitParam[1].ToString());
			EpiDataView reqedv = (EpiDataView)(oTrans.EpiDataViews["PartTran"]);
			reqedv.dataView[reqedv.Row]["ActTranQty"] = Convert.ToInt32(SplitParam[0].ToString());
			reqedv.dataView[reqedv.Row]["JobNum"] = Convert.ToString(SplitParam[1]);
			//Qty = Convert.ToInt32(SplitParam[0]);
			//JobNumber = Convert.ToString(SplitParam[1]);
		//EpiDataView reqedv = (EpiDataView)(oTrans.EpiDataViews[“MoveRequest”]);
		//reqedv.dataView[reqedv.Row]["JobNum"] = jobnumbertext;
/* object o = RcptToSalForm.LaunchFormOptions.ValueIn;
string[] values = (string[])o;
		EpiDataView edvReportParams = (EpiDataView)oTrans.EpiDataViews["PartTran"];
		MessageBox.Show(values[0].ToString());
		MessageBox.Show(values[1].ToString());
//edvReportParams.dataView[edvReportParams.Row][“ActTranQty”] = values[0];
//edvReportParams.dataView[edvReportParams.Row][“JobNum”] = values[1];
EpiDataView edv = ((EpiDataView)(this.oTrans.EpiDataViews[“PartTran”]));
//System.Data.DataRow edvMainRow = edv.CurrentDataRow;
//DataRow edv = ((EpiDataView)oTrans.EpiDataViews[“PartTran”]).CurrentDataRow;
			//EpiDataView edv = ((EpiDataView)(this.oTrans.EpiDataViews["PartTran"]));
			//System.Data.DataRow edvJobRcv = edv.CurrentDataRow;
			//if ((edvMainRow != null))
				MessageBox.Show("Qty - " + Convert.ToString(SplitParam[0]));
				edv.dataView[edv.Row]["PartTran.ActTranQty"] = SplitParam[0];
				edv.dataView[edv.Row]["PartTran.JobNum"] = SplitParam[1];
				MessageBox.Show("Part Number - " + Qty);
				MessageBox.Show("Job Number - " + JobNumber);
/*edvOrderHed.dataView[edvOrderHed.Row][“PONum”] = PartNumber;
edvOrderHed.dataView[edvOrderHed.Row][“PONum”] = JobNumber;
				edvMainRow["PartNum"] = PartNumber;
				edvMainRow["JobNum"] = JobNumber;
				edvMainRow.BeginEdit();
				edvMainRow["JobNum"] = Convert.ToString(SplitParam[0]);
				edvMainRow["PartNum"] = Convert.ToString(SplitParam[1]);
				edvMainRow.EndEdit();*/
			//edv["JobNum"] = Convert.ToString(SplitParam[0]);
			//edv["PartNum"] = Convert.ToString(SplitParam[1]);
			//rmAReceipt = Convert.ToInt32(SplitParam[2]);
			//MessageBox.Show(JobNumber.ToString());
			//MessageBox.Show(Qty.ToString());
private void edvPartTran_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
	// view.dataView[args.Row]["FieldName"]
	// args.Row, args.Column, args.Sender, args.NotifyType
	// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
	if ((args.NotifyType == EpiTransaction.NotifyType.AddRow))
		if ((args.Row > -1))
Please find the below screen shot:
