Glad it worked.
To “limit printingâ€, in your BAQ, the phrase builder tab, click on the Part table, and as a new criteria (bottom of the screen) for a blank PartNum. You can filter in Crystal too, but doing it in a BAQ will give you better performance.
Brian.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karl Dash
Sent: Tuesday, October 30, 2012 1:08 PM
Subject: Re: [Vantage] Parts NOT on Part Master
Brian, et al,
This is what worked. The Crystal report lists all parts on the JobProd but where there is no match to Part, the part number is blank. In order to reduce the number of pages, I may want to limit printing to only those parts that have a blank Part.partnum.
Thanks again -Karl
From: Brian Roberts <broberts@... <mailto:broberts%40gfxltd.com> >
Sent: Monday, October 29, 2012 1:46 PM
Subject: RE: [Vantage] Parts NOT on Part Master
Assuming you've made a BAQ report, and you clicked "outer join" in the
BAQ, then you want the following in Crystal: left outer join, not
enforced. Make sure the arrows are going the right way, in Crystal
*from* the parent table (JobProd) down to child (Part) - this is the
visual reverse of the arrows in the BAQ phrase builder.
Brian.
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf
Of Karl Dash
Sent: Monday, October 29, 2012 4:27 PM
To: Vantage Group
Subject: [Vantage] Parts NOT on Part Master
All,
We build either turnkey or consignment assemblies. Historically we
have not put the customer's part number on the Part master for
consignment assemblies. We want to do that now. So, I am looking for all
parts that are on the JobProd table but which are NOT on the Part
Master. I have created a Crystal report that has those two tables
attached to each other but am uncertain on what the join, enforce and
link types need to be to accomplish this.
-Karl
Brian.
Brian, et al,
Thanks again -Karl
Brian.
Of Karl Dash
To: Vantage Group
All,
-Karl
