PartBinInfo is intended to provide the data needed for permanent bin level kan-bans (as opposed to warehouse kanbans with only a primary bin specified).
As a side benefit, it also allows you to set up permanent relation ship between parts & whse/bins. When I say permanent, I mean the record will continue to exist when o/h qty in that whse bin reaches zero.
This is NOT true of PartBin. When o/h reaches zero for a PartBin, the record is removed until it is recreated again (by a receipt, transfer or adjustment transaction - a Parttrans record) that results in a non-zero (positive or negative) qty once again existing in the partbin.
Rob Brown
Sent: Friday, May 29, 2009 10:06:13 AM
Subject: [Vantage] Re: PartBin
Thanks for the response.
The option to use the PartBinInfo, would this add it to the PartBinInfo table in the database? I'm not sure what the differences between the PartBin and PartBinInfo tables are. The data dictionary says the partbininfo is an extention of the partbin, and stores information specific to KanBan (not sure what that is).
Rob Brown
--- In vantage@yahoogroups .com, "Stephen Edginton" <stephene@.. .> wrote:
> No not through business objects, you could through a BPM
> Another option is to use the PartBinInfo Table of the part, this is more
> persistent.
> PartBinInfo could be added via the PartAdapter.
> Regards,
> Stephen
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
> Of jed.sitzman
> Sent: 28 May 2009 23:09
> To: vantage@yahoogroups .com
> Subject: [Vantage] PartBin
> Is there anyway to update the partbin table through customizations? On
> the Receipt Entry screen, I'm trying to add a new record to the PartBin
> table. The only adapter that I found that has the PartBin table is the
> PartAdvisorAdapter, but there is no Update method. Any suggestions, or
> am I missing an adapter that can update this table?
> We are on Vantage 8.03.407. Thanks in advance.
