Weird one here. Has @hkeric.wci stuck as well. This is only happening in our DEV environment in our Global company. Only happens on Part updates, not new parts. The error is here:
Server Side Exception
A server error occurred. Review the server event logs for details.
Error Detail
Correlation ID: 238b388e-7907-404b-a922-7306f3c91345
Description: A server error occurred. Review the server event logs for details.
Program: Epicor.Ice.Server.Wcf.Core.dll
Method: ProvideFault
Line Number: 33
Column Number: 17
Server Trace Stack: at Epicor.Hosting.Wcf.ErrorHandler.ProvideFault(Exception error, MessageVersion version, Message& fault) in C:\_Releases\ICE\ICE3.2.700.0\Source\Framework\Ice.Server.Wcf.Core\Hosting\Wcf\ErrorHandler.cs:line 33
at System.ServiceModel.Dispatcher.ErrorBehavior.ProvideFault(Exception e, FaultConverter faultConverter, ErrorHandlerFaultInfo& faultInfo)
at System.ServiceModel.Dispatcher.ErrorBehavior.ProvideMessageFaultCore(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage8(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.ProcessError(Exception e)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener`1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.PartImpl.Update(PartDataSet ds)
at Erp.Adapters.PartAdapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Erp.UI.App.PartEntry.PartTransaction.AdapterUpdate()
at Erp.UI.App.PartEntry.PartTransaction.UpdateX()
And the server logs show this:
<Exception>< in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.Ice\SystemIntegration\Integration.cs:line 907
at Erp.Triggers.Part.WriteTrigger.quewrite(Part NewPart, Part OldPart) in C:\_releases\ERP\ERP10.2.700.0\Source\Server\Db\Triggers\Part\Write.cs:line 421
at Erp.Triggers.Part.WriteTrigger.Write(Part NewPart, Part OldPart) in C:\_releases\ERP\ERP10.2.700.0\Source\Server\Db\Triggers\Part\Write.cs:line 131
at Ice.DataTrigger`2.Ice.ILinqTrigger.Write(LinqRow newRecord, LinqRow oldRecord) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.Ice\Triggers\TriggerBase.cs:line 22
at Ice.Triggers.TriggerQueue.ExecuteWriteTrigger(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 298
at Ice.Triggers.TriggerQueue.RunWriteTriggerInNewLevel(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord, Boolean forAddedRow) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 156
at Ice.Triggers.TriggerQueue.<>c__DisplayClass9_0.<RunWriteTrigger>b__1() in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 147
at Ice.Triggers.TriggerQueue.RunAtNewLevel(Func`1 buildTriggerRunState, Action action) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 501
at Ice.Triggers.TriggerQueue.RunTriggers(IceDataContext context) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 82
at Ice.IceDataContext.RunUntilAllTriggersHaveExecuted() in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 565
at Ice.IceDataContext.Validate[TLinqRow](TLinqRow row) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 328
at Ice.TablesetBound`3.UpdateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow updatedRow, IceRow originalRow, IColumnUncensor uncensor, TablesetProfilingCollector parentTraceCollector) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1291
at Ice.TablesetBound`3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 980
at Ice.TablesetBound`3.InnerUpdate[TUpdater](IceDataContext dataContext, TFullTableset tableset) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 872
at Erp.Services.BO.PartSvc.Update(PartTableset& ds) in C:\_releases\ERP\ERP10.2.700.26\Source\Server\Services\BO\Part\Part.Designer.cs:line 6078
at Erp.Services.BO.PartSvcFacade.Update(PartTableset& ds) in C:\_releases\ERP\ERP10.2.700.26\Source\Server\Services\BO\Part\PartSvcFacade.cs:line 5927
at SyncInvokeUpdate(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:\_releases\ICE\ICE3.2.700.26\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 47
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\ICE3.2.700.0\Source\Framework\Ice.Server.Wcf.Core\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
ClientConnectionId:d8ef80f2-3b84-4d72-9620-855fc235b6a1
Error Number:515,State:2,Class:16]]></Exception>
The log references a UD column that is not being changed nor is it null. This happens in all customizations and in the base layer.
