Part List Ultra Grid View
Here is an example.
Â
Dim adaPartAdapter As PartAdapter = New PartAdapter(UD105Form)
Dim dsPartAdapter As Data.DataSet
Dim fields As String() = New String(){"PartNum","PartDescription"}
adaPartAdapter.BOConnect()
Dim optsPart As SearchOptions = New SearchOptions(SearchMode.AutoSearch)
optsPart.NamedSearch.WhereClauses.Add("Part", "Company = '" &
UD105Form.Session.CompanyID & "' AND PartNum = '" & etbPartNum.Text & "'")
Dim MorePagesPart As Boolean
dsPartAdapter = adaPartAdapter.GetRows(optsPart, MorePagesPart)
ucbEpiCustom6.DataSource = dsPartAdapter.Tables("Part")
ucbEpiCustom6.ValueMember = "PartNum"
ucbEpiCustom6.DisplayMember = "PartDescription"
ucbEpiCustom6.SetColumnFilter(fields)
Sent: Mon, October 4, 2010 10:42:06 AM
Subject: [Vantage] Re: Part List Ultra Grid View
Â
I'm not sure which route we're going to go, but the fields I would need to
filter on would be VB fields Character01 and CheckBox1-3. So If you wouldn't
mind providing an example of how I could utilize the PartAdapter directly.
Thanks.
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> Yes, but only for the fields returned by the Search Function. If you wish to
> access the entire Part table, then you would have to call the PartAdapter
> directly, which is much slower. Let me know if you need an example of this.
> From: bobschnable <bschnable@...>
> Sent: Fri, October 1, 2010 5:21:04 PM
> ÂÂ
> Thanks Steven that's perfect. I assume by utilizing the whereClause parameter I
> can filter out my data set as I wish?
> --- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@> wrote:
> > Here is one way. Add This to your form's on load event. Change
> >ugdEpiCustom1
> > to the name of your ultragrid.
> > Dim recSelected As Boolean
> > Dim whereClause As String = String.Empty
> > Dim dsPartAdapter As DataSet =
> > Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans, "PartAdapter"
> > recSelected, False, whereClause)
> > ugdEpiCustom1.DataSource = dsPartAdapter.Tables(0)
> > ÂÂÂ
> > From: bobschnable <bschnable@>
> > Sent: Fri, October 1, 2010 4:15:07 PM
> > Subject: [Vantage] Part List Ultra Grid View
> > ÂÂÂ
> > Hello Group,
> > I have added an Ultra Grid view to Part Setup, under the Part Rev tab. When I
> > use the Part as the data source, it only display the current part I'm
>selected
> > on in the grid view, which is what I expected.
> > I want to display the entire part list in this grid view however. I am at a
> > loss.
> > Thanks in advance for the help.
> > Bob
Hello Group,
I have added an Ultra Grid view to Part Setup, under the Part Rev tab. When I use the Part as the data source, it only display the current part I'm selected on in the grid view, which is what I expected.
I want to display the entire part list in this grid view however. I am at a loss.
Bob
Here is one way. Add This to your form's on load event. Change ugdEpiCustom1
Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans, "PartAdapter" ,
Â
Â
Hello Group,
loss.
Bob
Thanks Steven that's perfect. I assume by utilizing the whereClause parameter I can filter out my data set as I wish?
> ÂÂ
> ÂÂ
> Hello Group,
> loss.
> Bob
Bob,
The easiest way I know of is to create a BAQ with all of the parts and use the DynamicQueryAdapter to display them. I can send you the code if you need it.
Jeff Sanders
--- In vantage@yahoogroups.com, "bobschnable" <bschnable@...> wrote:
> Hello Group,
> Bob
Â
>ugdEpiCustom1
> ÂÂ
> ÂÂ
> Hello Group,
> loss.
> Bob
I'm not sure which route we're going to go, but the fields I would need to filter on would be VB fields Character01 and CheckBox1-3. So If you wouldn't mind providing an example of how I could utilize the PartAdapter directly.
Thanks.
> ÂÂ
> >ugdEpiCustom1
> > ÂÂÂ
> > ÂÂÂ
> > Hello Group,
> > loss.
> > Bob
