We’re trying to mark an item as inactive and getting the error ‘Part cannot be marked as inactive if there is quantity allocated’. It’s a non stock item and a phantom BOM…
I’ve run the Refresh Part Quantities and Allocations Report only and receive a no records selected error
I’ve looked in the PartDtl table, part isn’t in there
I’ve looked at Part Tracker, item is in 2 warehouses and both have a quantity on hand of 0, which makes sense as it’s a non stock item…
I’ve looked in the material queue, it’s also not there.
What am I missing? Is there some other place this might be hiding? .
I tried that and got the error ‘Cannot delete part that has on hand quantity’… Except it doesn’t have any on hand, it’s a non stocked item. Both the Qty On Hand and Non Nettable Qty in Part Tracker show 0 on hand.
Yeah, I’ve been trying BAQs and still haven’t had any luck. I am waiting to hear back from support lol… I gave up for the time being. But I’ll update when I have more info.
Or just ‘cheat’ and pop in an EpiCare case. I bet that’s happened before. You might get a KB article pointing out the fix, or a a request for a BAQ of some table, and a datafix response.
Adjust your decimals for the UOM of the part to the max allowable (8?).
In the past I have also run into issues where i cannot inactivate a part because of inventory on hand. Part Tracker shows 0.00, but when i increased the decimals there would be some qty like 0.00000084 EA. Qty adjust that out and then inactivate.
Note: after increasing the decimals allowable for the UOM Code you’ll need to restart Epicor to see it.
