Im looking for information on how to setup the part entry setup for the Parent Part for our Sales kit configuration.
Also i cant get that information to show up in configurator rules either.
There is a Setting Up Sales Kitting documentation in the help. In short:
As far as using the Configurator to do a sales kit, I’m not sure on that one. I’m a bit of a configurator newbie. Pretty sure It could be done, not sure how you pass the qtys back from to the SO, perhaps on the close or a document rule. Just remember the part needs to have the right combination of non-stock and qty bearing flags for it to be configurable (if I remember correctly)
The Sales kit parameters allow you to alter the quantity and shipping options (amongst other things).
Parent part for a sales kit needs to be quantity bearing. You can flag it non-stock or stockable depending on your circumstances/needs. IF you are making it configurable, you will need to mark it non-stock = TRUE. All children parts of sales kits must be non-stock = FALSE and qty-bearing = TRUE.
What info are you trying to get to show in the rules?
