In Multi-Plant 4.0
We do not assign the GL number at the part level but at the Purchase order
we define the part class with a gl account. The division defaults based on
the plant you are in when the P.O. is created.
In multi-plant, I believe the default (Plant/Division) will be the plant
that
you are in when you enter the purchase order. If the plant you are in when
entering the order is not on the list of plants, the default From plant is
the first plant listed in the part master for that part. If the plant you
are in when you enter the order is a valid plant for this part, then the
plant you are in will be the default plant.
Good Luck
Don Kollmann
donk@...
that
Good Luck
Don Kollmann
donk@...
