Part Attribute Image in SSRS
I am both new to SSRS and to E10. I was wondering if anyone out there has successfully embedded the image associated with a part to a SSRS report? I am currently trying to do it on the Job Traveler. Thanks!
Hi Brandon,
Have any luck doing this?
Joe
How is the image associated as a part? As an attachment? The file location would need to be included in your dataset somehow. Once you have a file path in your data set you can set the function of an image source to a field in your dataset. You would set the function to something like =“file:” + Fields!{PUT FILE FULL PATH LOCATION FIELD HERE}.Value
