Parent part, Sub Parts/Assemblies, material parts
Hey everyone,
So I have been tasked with getting a part tree created in Epicor BAQ from Parent Part, all the way to the bones.
I am struggling to find a relationship that I can use to keep the data accurate. I’ve tried using jobhead.jobnum, but with no luck, and I have tried using part.classid FG and go down from there, but no matter what it seems I can only get 2 rows of part numbers. I am looking for 3. raw material into sub component, and sub into final part number. The only link I can find in Epicor 10 Is “Where Used”. I have no clue how this is pulling its data, but if anyone knows of a table of some identifier to link these numbers together, that would be a huge help.
Thank you very much.
in E10 in the Help for BAQ’s there is a CTE example of an Epicor Multi-Level BAQ BOM (assuming this is what you want)
I followed this example, and its very hard to follow what im actually doing, but I got it done and It seems I can only look up one part number at a time. My bosses would like this for every part number. any ideas?
You should be able to remove any filters and then it should work for any part number… I’d have to see what you have to give you specific help.
No Filters, just an Action. I removed the action and now it doesn’t have any parts to search. ill mess with it and see if I can get anything.
With [SubQuery1] AS
(select
	[PartMtl].[Company] as [PartMtl_Company],
	[PartMtl].[PartNum] as [PartMtl_PartNum],
	[PartMtl].[RevisionNum] as [PartMtl_RevisionNum],
	[PartMtl].[MtlSeq] as [PartMtl_MtlSeq],
	[PartMtl].[MtlPartNum] as [PartMtl_MtlPartNum],
	[PartMtl].[QtyPer] as [PartMtl_QtyPer],
	[PartMtl].[RelatedOperation] as [PartMtl_RelatedOperation],
	[PartMtl].[PullAsAsm] as [PartMtl_PullAsAsm],
	[PartMtl].[ViewAsAsm] as [PartMtl_ViewAsAsm],
	[PartMtl].[PlanAsAsm] as [PartMtl_PlanAsAsm],
	(0) as [Calculated_Hierarchy],
	(cast ( substring('........',1 ,(Hierarchy + 1) ) + PartMtl.MtlPartNum
 as nvarchar(25))) as [Calculated_Ind1]
from Erp.PartMtl as PartMtl
 where PartMtl.PartNum = @PartNum
UNION ALL
select
	[PartMtl1].[Company] as [PartMtl1_Company],
	[PartMtl1].[PartNum] as [PartMtl1_PartNum],
	[PartMtl1].[RevisionNum] as [PartMtl1_RevisionNum],
	[PartMtl1].[MtlSeq] as [PartMtl1_MtlSeq],
	[PartMtl1].[MtlPartNum] as [PartMtl1_MtlPartNum],
	[SubQuery1].[PartMtl_QtyPer] as [PartMtl_QtyPer],
	[PartMtl1].[RelatedOperation] as [PartMtl1_RelatedOperation],
	[PartMtl1].[PullAsAsm] as [PartMtl1_PullAsAsm],
	[PartMtl1].[ViewAsAsm] as [PartMtl1_ViewAsAsm],
	[PartMtl1].[PlanAsAsm] as [PartMtl1_PlanAsAsm],
	(Calculated_Hierarchy + 1) as [Calculated_Hierarchy2],
	(cast ( substring('........',1 ,(Hierarchy2 + 1) ) + PartMtl1.MtlPartNum
 as nvarchar(25))) as [Calculated_Ind2]
from Erp.PartMtl as PartMtl1
inner join  SubQuery1  as SubQuery1 on
	SubQuery1.PartMtl_MtlPartNum = PartMtl1.PartNum
And
	SubQuery1.PartMtl_Company = PartMtl1.Company)
select
	[SubQuery11].[PartMtl_Company] as [PartMtl_Company],
	[SubQuery11].[PartMtl_PartNum] as [PartMtl_PartNum],
	[SubQuery11].[PartMtl_RevisionNum] as [PartMtl_RevisionNum],
	[SubQuery11].[PartMtl_MtlSeq] as [PartMtl_MtlSeq],
	[SubQuery11].[PartMtl_MtlPartNum] as [PartMtl_MtlPartNum],
	[SubQuery11].[PartMtl_QtyPer] as [PartMtl_QtyPer],
	[SubQuery11].[PartMtl_RelatedOperation] as [PartMtl_RelatedOperation],
	[SubQuery11].[PartMtl_PullAsAsm] as [PartMtl_PullAsAsm],
	[SubQuery11].[PartMtl_ViewAsAsm] as [PartMtl_ViewAsAsm],
	[SubQuery11].[PartMtl_PlanAsAsm] as [PartMtl_PlanAsAsm],
	[SubQuery11].[Calculated_Hierarchy] as [Calculated_Hierarchy],
	[SubQuery11].[Calculated_Ind1] as [Calculated_Ind1]
from  SubQuery1  as SubQuery11
Here is what I use directly in SQL.
WITH PartsExplosion (PartNum, MtlPartNum, lv, QtyPer, rowid, Name, SORT)
AS (
-- Anchor This is the parent part selection
  SELECT Erp.Part.PartNum,
         Erp.Part.PartNum,
         0,
         cast(Erp.Part.PurchasingFactor as int) as QtyPer,
         Erp.Part.SysRowID,
         CAST(Erp.Part.PartDescription as nvarchar(100)) as Name,
         CAST('\' + Erp.Part.PartDescription as nvarchar(254)) as Sort
FROM Erp.Part
WHere ClassID in ('FGD', 'FGA')
-- Recursive Call This is the BOM for each parent
UNION ALL
SELECT BOM.PartNum, BOM.MtlPartNum, lv + 1, cast(BOM.QtyPer as int) as QtyPer, BOM.SysRowID,
       CAST(REPLICATE ('|    ' , lv + 1 ) + BOM.PartDescription as nvarchar(100)),
       CAST(cte.Sort + '\' +  BOM.PartDescription as nvarchar(254))
FROM PartsExplosion CTE
JOIN (SELECT Erp.PartMtl.PartNum , Erp.PartMtl.MtlPartNum, cast(Erp.PartMtl.QtyPer as int) as QtyPer, Erp.PartMtl.SysRowID, b.PartDescription
FROM Erp.PartMtl Join Erp.Part AS b on Erp.PartMtl.MtlPartNum = b.PartNum
inner join dbo.PartRev on Erp.PartMtl.RevisionNum = dbo.PartRev.RevisionNum and Erp.PartMtl.PartNum = dbo.PartRev.PartNum and Erp.PartMtl.Company = dbo.PartRev.Company
WHERE dbo.PartRev.Approved = 1
) AS BOM
ON CTE.MtlPartNum = BOM.PartNum
select Name,pe.QtyPer, PartNum,PE.MtlPartNum,  lv--,sort
FROM PartsExplosion AS PE
ORDER BY sort
This is only showing one part, remove this line.
Works perfectly now. Thank you all very much!
Is there any way to reverse this which would allow for an end item, where used?
