Paperless on Shop Floor
...nearly forgot, we also stamp the part numbers on the materials whenever practical.
--- In vantage@yahoogroups.com, "Kerry_Muntz" <kerry_muntz@...> wrote:
> Hi, firstly, do you know 'why' you want to be paperless? Is it just because it's perceived to be a green thing? Is it because the current paperwork is confusing? What are you willing to sacrifice for it?
> We had a reduced paperwork environment - where any sheetmetal jobs did not get a paper traveller. Instead they got a spreadsheet of the required work (custom cutlist), that enabled basic planning by our punch operator, as well as custom stickers (address label size) with all qty, routing and material info etc that would be attached to a part belonging to each job. Labour was captured, so tracking was easy via reports. Job washup would be done en-mass via reports that would filter out the jobs with major descrepancies. Jobs with acceptable variances were closed via macros. We had this running both on 6.1 and 8.03.405 before going "Lean".
> Lean promised us many things, including a reduction in paperwork. I don't know whether paperwork is reduced. T-cards (mini job cards) are now used for many things, though we don't really manage jobs in the traditional sense anymore. I'm not a believer, so I'm probably going to be pretty biased. We kanban-receipt finished products only, and everything in between is assumed to have been produced as per bom or quote. IMO it doesn't really suit production environments with high product variation.
> If anything mentioned above helps, I'd be happy to go into it further.
> Kerry.
> --- In vantage@yahoogroups.com, Norman Hutchins <nhutchins@> wrote:
> > Wondering if there is anyone running paperless on the shop floor (job queues
> > in MES), that might be willing to have a brief conference call with our
> > production group.
> > Paperless is our goal, but we are struggling on how to make it work and
> > would love to pick someone else's brain for a bit.
> > Norman Hutchins
> > Network Administrator
> > Howell Laboratories, Inc.
> > Shively Labs
> > 207-647-3327
> > ____________________________________________________________________
> > This email was sent by Howell Laboratories, Inc. or Shively Labs. It may
> > contain information that is confidential or privileged. If you suspect you
> > were not intended to receive it, please delete it without copying or
> > forwarding it, and notify the sender by reply email or by
> > calling 207-647-3327.
production group.
would love to pick someone else�s brain for a bit.
Norman Hutchins
Shively Labs
207-647-3327
We would love to do the same.
Starting end of the month with MES in epicor 9.
If you get some good advise I would like to tune in to it
Ephraim Feldman
Date: Mon, 7 Jun 2010 17:12:53
To: <vantage@yahoogroups.com>
Subject: [Vantage] Paperless on Shop Floor
production group.
would love to pick someone else’s brain for a bit.
Norman Hutchins
Shively Labs
207-647-3327
Metalworks is a Make-To-Order FIFO value stream based lean environment. With all those buzz words you'd think we would be paperless, but we are not. Priinting the paper at the point of use is the closest we could get, so far. We are implementing 9.05.600 and will use the auto print functions extensively.
We alrealdy have 40+ MES stations and the amount of additional computer screens we would need within work cells to place the Job information at the various stations would be extensive and expensive.
There may be other industries that are a better fit for paperless.
Brad Boes
Metalworks
> production group.
> Norman Hutchins
> Shively Labs
> 207-647-3327
Without a paper job traveler stuck to the pallet of parts, how do you know what job it is, or even what part it is?
Original Message ----
Sent: Mon, June 7, 2010 4:12:53 PM
production group.
Norman Hutchins
Shively Labs
207-647-3327
Kerry.
> production group.
> Norman Hutchins
> Shively Labs
> 207-647-3327
