Hi,
I am creating a packslip with multiple lines using BPM. with this following code I am able to create first line. at the time of 2nd iteration foreach I am getting ‘Object reference error- in
GetNewOrdrShipDtl method.’. I really appreciate your help with this.
//This BPM is used to create the Packslip with the UD101 data.
var ttrow = (from row in ttUD101 where row.Company == Session.CompanyID && (row.RowMod == "A" || row.RowMod == "U")&& row.Character04 =="True" /* "Create PackSlip"*/ select row).FirstOrDefault();
if(ttrow != null)
try
int orderNum = Convert.ToInt32(ttrow.Key2);//5631;
int custNum = 0;
var dbOrderHed = (from row in Db.OrderHed where row.Company == Session.CompanyID && row.OrderNum == orderNum select row).FirstOrDefault();
if(dbOrderHed != null)
custNum= Convert.ToInt32(dbOrderHed.CustNum);
string creditMessage = "";
string shipToCustomerList = "";
int iShipToCustNum = custNum;//13331;
string shipToList = "";
int ipPackNum = 0;
bool opPromptForNum = false;
int lineNum = 0;
bool belongToAnotherPC = false;
string pcOutsideMessage= "";
bool cError,compError,updateComplete,checkComplianceError,changeStatusError,checkShipDtlAgain = false;
string opReleaseMessage,opCompleteMessage,opShippingMessage,opLotMessage,opInventoryMessage,opLockQtyMessage,opAllocationMessage,opPartListNeedsAttr,opLotListNeedsAttr,shipCreditMsg,msg,opPostUpdMessage = "";
string partNum = "";
string vMsgText,vMsgType,origPartNum = "";
bool vSubAvail = false;
int ipBTCustNum = custNum;//13331;
// using (var Txscope = IceContext.CreateDefaultTransactionScope())
var svc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.CustShipSvcContract>(Db);
Erp.Tablesets.CustShipTableset CT;
CT = new Erp.Tablesets.CustShipTableset();
svc.GetNewShipHead(ref CT);
svc.GetHeadOrderInfo(orderNum,out creditMessage,ref CT);
svc.BuildShipToCustomerList(orderNum,out shipToCustomerList);
svc.BuildShipToList(orderNum,iShipToCustNum,out shipToList);
svc.GetLegalNumGenOpts(ipPackNum,ref CT, out opPromptForNum);
svc.CheckPCBinOutLocation(ref CT,out lineNum,out belongToAnotherPC, out pcOutsideMessage);
CT.ShipHead[0].ShipDate = Convert.ToDateTime(DateTime.Now);
//CT.ShipHead[0].ShipViaCode = "UPS";
CT.ShipHead[0].CustNum = custNum;//13331;
CT.ShipHead[0].Plant = Session.PlantID.ToString();
CT.ShipHead[0].RowMod = "A";
svc.UpdateMaster(ref CT,false,false,false,false,false,false,false,ipPackNum,iShipToCustNum,out opReleaseMessage,out opCompleteMessage,out opShippingMessage,out opLotMessage,out opInventoryMessage,out opLockQtyMessage,out opAllocationMessage,out opPartListNeedsAttr,out opLotListNeedsAttr,out shipCreditMsg,out cError,out compError,out msg,out opPostUpdMessage,out updateComplete,out checkComplianceError,out changeStatusError,out checkShipDtlAgain);
int Packnum = CT.ShipHead[0].PackNum;
InfoMessage.Publish("Header Created"+Packnum.ToString());
string company = CT.ShipHead[0].Company;
int rowIndex = 0;
foreach(var DbPackslipRow in(from row in Db.UD101 where row.Company == Session.CompanyID && row.Key2 == ttrow.Key2 select row))
int ipOrderNum = 0;
string pcWarningMsg,cWarning,ipPCID= "";
// string ipPCID = "";
svc.POGetNew(ipOrderNum,Packnum,out pcWarningMsg);
string ipPackMode = "PACK";
svc.POGetDtlList(Packnum,ipPCID,orderNum,ipPackMode,out cWarning);
InfoMessage.Publish(orderNum.ToString()+" order num");
svc.GetNewOrdrShipDtl(ref CT,Packnum,orderNum);
InfoMessage.Publish("shipdtl --1");
svc.GetOrderInfo(orderNum,out creditMessage,ref CT);
//svc.GetManifestInfo(orderNum,Packnum,ref CT);
//svc.GetListFilterShipped();
int orderLine = Convert.ToInt32(DbPackslipRow.Key3);
svc.CheckPrePartInfo(ref partNum,orderNum,orderLine,out vMsgText,out vSubAvail,out vMsgType,out origPartNum);
int packLine = 0;
int orderRelNum = Convert.ToInt32(DbPackslipRow.Key4);
string subsPart = "";//"8700-1251-900";
var dbOrderRel = (from row in Db.OrderRel where row.Company == Session.CompanyID && row.OrderNum == orderNum && row.OrderLine == orderLine && row.OrderRelNum == orderRelNum select row).FirstOrDefault();
if(dbOrderRel != null)
subsPart = Convert.ToString(dbOrderRel.PartNum);
svc.GetOrderLineInfo(ref CT,packLine,orderLine,subsPart);
bool allowNewShipTo = true;
svc.GetOrderRelInfo(ref CT,packLine,orderRelNum,allowNewShipTo);
InfoMessage.Publish("Display Inv QTY--1");
CT.ShipDtl[rowIndex].DisplayInvQty = Convert.ToInt32(DbPackslipRow.Number01);
InfoMessage.Publish("Disply --2");
//SERIAL TRACKED PART CODE START
var dbPart = (from row in Db.Part where row.Company == Session.CompanyID && row.PartNum == subsPart select row).FirstOrDefault();
if(dbPart != null)
if(dbPart.TrackSerialNum == true)
string ipPartNum = dbPart.PartNum.ToString();
decimal ipQuantity = Convert.ToInt32(DbPackslipRow.Number01);//CT.ShipDtl[0].OurInventoryShipQty;
string ipUOM = CT.ShipDtl[rowIndex].InventoryShipUOM.ToString();
//int ipPackNum = CT.ShipDtl[0].PackNum;
int ipPackLine = CT.ShipDtl[rowIndex].PackLine;
string ipTranType = "STK-PCK";
string ipJobNum = CT.ShipDtl[rowIndex].JobNum.ToString();//"";
string ipWhseCode = CT.ShipDtl[rowIndex].WarehouseCode.ToString();
string ipBinNum = CT.ShipDtl[rowIndex].BinNum.ToString();
string ipLotNum = CT.ShipDtl[rowIndex].LotNum.ToString();
InfoMessage.Publish(ipWhseCode.ToString()+"wh "+ipBinNum.ToString()+"Bin");
bool ipFromPO = false;
int ipOrderLine = CT.ShipDtl[rowIndex].OrderLine;
int ipOrderRelNum = CT.ShipDtl[rowIndex].OrderRelNum;
Guid ipSysRowID = new Guid("00000000-0000-0000-0000-000000000000");
svc.GetSelectSerialNumbersParams(ipPartNum,ipQuantity,ipUOM,ipPackNum,ipPackLine,ipTranType,ipJobNum,ipWhseCode,ipBinNum,ipLotNum,ipFromPO,ipOrderNum,ipOrderLine,ipOrderRelNum,ipSysRowID);
var SSNBO = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.SelectedSerialNumbersSvcContract>(Db);
Erp.Tablesets.SelectedSerialNumbersTableset ssnTs = new Erp.Tablesets.SelectedSerialNumbersTableset();
string xrefPartNum = string.Empty;
string xrefPartType = string.Empty;
int xrefCustNum = 0;
SSNBO.GetSerialNumFormat(ref ssnTs, ipPartNum, xrefPartNum, xrefPartType, xrefCustNum, Session.PlantID.ToString());
// SELECTING SERIAL NUMBERS START
var dbSerialNums = (from row in Db.UD101A where row.Company == Session.CompanyID && row.Key1 == DbPackslipRow.Key1 && row.Key2 == DbPackslipRow.Key2 && row.Key3 == DbPackslipRow.Key3 && row.Key4 == DbPackslipRow.Key4 && row.Key5 == DbPackslipRow.Key5 select row).ToList();
if(dbSerialNums.Count > 0)
foreach(var SerialNum in dbSerialNums)
var SerialNoBO = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.SerialNoSvcContract>(Db);
Erp.Tablesets.SerialNoTableset snTs = new Erp.Tablesets.SerialNoTableset();
string partNum1 = "";
SerialNoBO.GetNewSerialNo(ref snTs, partNum1); // Create new serial number
string SerialNumber = SerialNum.ShortChar01.ToString();
snTs.SerialNo[0].SerialNumber = SerialNum.ShortChar01.ToString(); // Inserting serial number
snTs.SerialNo[0].SNReference = "Test Ref"; // Reference
string pcProposedPartNum = ipPartNum;//dbPart.PartNum.ToString();
string custID = "";
SerialNoBO.ChangePartNum(pcProposedPartNum, ref snTs); // Assign part to the serial number
var dbcustrow = (from row in Db.Customer where row.Company == Session.CompanyID && row.CustNum == custNum select row).FirstOrDefault();
if(dbcustrow != null)
custID = Convert.ToString(dbcustrow.CustID);
string proposedCustID = custID;//dbCustomer.CustID.ToString();
SerialNoBO.ChangeCustomerID(proposedCustID, ref snTs); // Assign customer to serial number
SerialNoBO.Update(ref snTs);
bool snExists = false;
SerialNoBO.SerialNumberExists(SerialNumber, out snExists); // Check if serial number exists
SerialNoBO.Update(ref snTs); // Save the serial number
// SerialNoBO.Dispose();
InfoMessage.Publish("Serial Number saved");
// Changing values after update----
var dbSerialNoAfter = (from row in Db.SerialNo where row.Company == Session.CompanyID && row.SerialNumber == SerialNumber select row).FirstOrDefault();
if(dbSerialNoAfter != null)
dbSerialNoAfter.SNStatus = "INVENTORY"; // Serial Number Status
dbSerialNoAfter.WareHouseCode = ipWhseCode;// "MAIN"; // Warehouse Code
dbSerialNoAfter.BinNum = ipBinNum;//"10A1"; // BinNum
Db.Validate();
InfoMessage.Publish("Serial Number status changed");
SSNBO.AddSerialNum(ref ssnTs, ipPartNum, xrefPartNum, xrefPartType, xrefCustNum, SerialNum.ShortChar01.ToString(), Guid.Empty.ToString(), "STK-PCK", Session.PlantID.ToString());
// SELECTING SERIAL NUMBERS END
// Adding the selected serials to custship tableset START
for(int i = 0; i < ssnTs.SelectedSerialNumbers.Count; i++)
var ssnrow = CT.SelectedSerialNumbers.NewRow();
ssnrow["Company"] = ssnTs.SelectedSerialNumbers[i].Company;
ssnrow["SerialNumber"] = ssnTs.SelectedSerialNumbers[i].SerialNumber;
ssnrow["Scrapped"] = ssnTs.SelectedSerialNumbers[i].Scrapped;
ssnrow["ScrappedReasonCode"] = ssnTs.SelectedSerialNumbers[i].ScrappedReasonCode;
ssnrow["Voided"] = ssnTs.SelectedSerialNumbers[i].Voided;
ssnrow["Reference"] = ssnTs.SelectedSerialNumbers[i].Reference;
ssnrow["ReasonCodeType"] = ssnTs.SelectedSerialNumbers[i].ReasonCodeType;
ssnrow["ReasonCodeDesc"] = ssnTs.SelectedSerialNumbers[i].ReasonCodeDesc;
ssnrow["PartNum"] = ssnTs.SelectedSerialNumbers[i].PartNum;
ssnrow["SNPrefix"] = ssnTs.SelectedSerialNumbers[i].SNPrefix;
ssnrow["SNBaseNumber"] = ssnTs.SelectedSerialNumbers[i].SNBaseNumber;
ssnrow["SourceRowID"] = Guid.Empty; //tsSelSerials.SelectedSerialNumbers[i].SourceRowID;
ssnrow["TransType"] = ssnTs.SelectedSerialNumbers[i].TransType;
ssnrow["PassedInspection"] = ssnTs.SelectedSerialNumbers[i].PassedInspection;
ssnrow["Deselected"] = ssnTs.SelectedSerialNumbers[i].Deselected;
ssnrow["KitWhseList"] = ssnTs.SelectedSerialNumbers[i].KitWhseList;
ssnrow["RawSerialNum"] = ssnTs.SelectedSerialNumbers[i].RawSerialNum;
ssnrow["KBLbrAction"] = ssnTs.SelectedSerialNumbers[i].KBLbrAction;
ssnrow["KBLbrActionDesc"] = ssnTs.SelectedSerialNumbers[i].KBLbrActionDesc;
ssnrow["PreventDeselect"] = ssnTs.SelectedSerialNumbers[i].PreventDeselect;
ssnrow["XRefPartNum"] = ssnTs.SelectedSerialNumbers[i].XRefPartNum;
ssnrow["XRefPartType"] = ssnTs.SelectedSerialNumbers[i].XRefPartType;
ssnrow["PreDeselected"] = ssnTs.SelectedSerialNumbers[i].PreDeselected;
ssnrow["poLinkValues"] = ssnTs.SelectedSerialNumbers[i].poLinkValues;
ssnrow["SNMask"] = ssnTs.SelectedSerialNumbers[i].SNMask;
ssnrow["NotSavedToDB"] = ssnTs.SelectedSerialNumbers[i].NotSavedToDB;
//ssnrow["RowSelected"] = ssnTs.SelectedSerialNumbers[i].RowSelected;
ssnrow["SysRowID"] = Guid.Empty; //tsSelSerials.SelectedSerialNumbers[i].SysRowID;
ssnrow["RowMod"] = "A";
CT.SelectedSerialNumbers.Add(ssnrow);
InfoMessage.Publish("sn created");
// Adding selected serials to custship tableset END
// SSNBO.Dispose();
// Txscope.Complete();
//------ SERIAL TRACKED PART CODE END
var dbPart_Lot = (from row in Db.Part where row.Company == Session.CompanyID && row.PartNum == subsPart select row).FirstOrDefault();
if(dbPart_Lot != null)
// TRACKLOT PART CODE START
if(dbPart_Lot.TrackLots == true)
var LSUBO = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.LotSelectUpdateSvcContract>(Db);
Erp.Tablesets.PartLotListTableset partlotlistTs = new Erp.Tablesets.PartLotListTableset();
string whereClause = "(PartNum = '"+subsPart+"') AND Onhand = true";//(PartNum = '00M3') AND OnHand = true
int pageSize = 100;
int absolutePage = 0;
bool morePages = false;
partlotlistTs = LSUBO.GetListByBinNum(ipWhseCode,ipBinNum,whereClause,pageSize,absolutePage, out morePages);
CT.ShipDtl[rowIndex].LotNum = partlotlistTs.PartLotList[0].LotNum.ToString();
// LSUBO.Dispose();
//--------- TRACKLOT PART CODE END
svc.CheckPCBinOutLocation(ref CT,out lineNum,out belongToAnotherPC,out pcOutsideMessage);
bool doValidateCreditHold,doCheckShipDtl = false;
CT.ShipHead[0].RowMod = "U";
CT.ShipDtl[rowIndex].PackNum = Packnum;
CT.ShipDtl[rowIndex].PackLine = packLine;
CT.ShipDtl[rowIndex].OrderLine = orderLine;
CT.ShipDtl[rowIndex].OrderRelNum = orderRelNum;
CT.ShipDtl[rowIndex].LineType = "PART";
CT.ShipDtl[rowIndex].OurInventoryShipQty = Convert.ToDecimal(DbPackslipRow.Number01);
CT.ShipDtl[rowIndex].Packages = 1;
CT.ShipDtl[rowIndex].PartNum = subsPart;
// CT.ShipDtl[0].WarehouseCode = "CHI";
// CT.ShipDtl[0].BinNum = "01-01-02";
CT.ShipDtl[rowIndex].RowMod = "A";
InfoMessage.Publish("before update");
svc.UpdateMaster(ref CT,false,false,false,false,false,false,false,Packnum,ipBTCustNum,out opReleaseMessage,out opCompleteMessage,out opShippingMessage,out opLotMessage,out opInventoryMessage,out opLockQtyMessage,out opAllocationMessage,out opPartListNeedsAttr,out opLotListNeedsAttr,out shipCreditMsg,out cError,out compError,out msg,out opPostUpdMessage,out updateComplete,out checkComplianceError,out changeStatusError,out checkShipDtlAgain);
InfoMessage.Publish("Packslip Created. Packslip No:"+Packnum.ToString());
rowIndex = rowIndex++;
ttrow.ShortChar01 = "PackSlip Created";
ttrow.Character01 = Packnum.ToString(); // storing in UD101 PackNum
InfoMessage.Publish("end");
// Db.Validate();
// svc.Dispose();
catch(Exception e)
InfoMessage.Publish(e.Message.ToString());
ttrow.Character02 = e.Message.ToString();
