One of our customers needs a very basic custom Packing Slip for their dropship orders. So I created a BAQ with the needed information and an SSRS report for the packing slip. The packing slip runs fine on it’s own when testing from BAQ Report Designer --> Actions --> Test Report Form, but when I create a report style and print from Customer Shipment form I get the below error from System Monitor. I believe I’m missing a means to pass the Pack Slip ID to the form to filter.
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: Value cannot be null.
Parameter name: key
Stack Trace:
at System.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument)
at System.Collections.Generic.Dictionary2.FindEntry(TKey key) at System.Collections.Generic.Dictionary
2.TryGetValue(TKey key, TValue& value)
at Epicor.Utilities.DictionaryExtensions.GetOrAdd[TKey,TValue](IDictionary2 dictionary, TKey key, Func
2 valueFactory) in C:_Releases\ICE\ICE3.2.200.9\Source\Shared\Framework\Epicor.ServiceModel\Utilities\DictionaryExtensions.cs:line 24
at Ice.Core.RptBase.ReportDataBuilderBase.XMLDumpTable(IRow row, String rptTableId) in C:_Releases\ICE\ICE3.2.200.9\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDataBuilderBase.cs:line 336
at Erp.Internal.SR.PackingSlipPrint.doShipDtl() in C:_Releases\ERP\UD10.2.200.9\Source\Server\Internal\SR\PackingSlipPrint\PackingSlipPrint.cs:line 2010
at Erp.Internal.SR.PackingSlipPrint.RunProcess(Int64 Instance_TaskNum, String OutputFile) in C:_Releases\ERP\UD10.2.200.9\Source\Server\Internal\SR\PackingSlipPrint\PackingSlipPrint.cs:line 942
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_Releases\ICE\ICE3.2.200.9\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_Releases\ICE\ICE3.2.200.9\Source\Server\Services\Lib\RunTask\RunTask.cs:line 549
This is the BAQ Report designer screenshot
Report Style Maintenance
