Dear Team,
I’m trying to refresh the part form once the revision is deleted from the last to first (one by one). I’m getting the error message like Index 0 is either one or more row count. but the revision is deleted from the part. kindly help on this issue. I’m using the After Adapter Method. I commented on the oTrans.Refresh() method and used the other format also.
The below custom code is used for your reference.
private void oTrans_adapter_AfterAdapterMethod(object sender, AfterAdapterMethodArgs args)
// ** args.MethodName **
// ** Add Event Handler Code **
// ** Use MessageBox to find adapter method name
// EpiMessageBox.Show(args.MethodName);
switch (args.MethodName)
case "GetByID":
Ice.Lib.Framework.EpiCombo epiCmbItemGrp = (Ice.Lib.Framework.EpiCombo)csm.GetNativeControlReference("e405d5e7-d88d-4237-93fe-de6bfa1a0eb1");
Ice.Lib.Framework.EpiCombo epiCmbItemSubGrp = (Ice.Lib.Framework.EpiCombo)csm.GetNativeControlReference("30594709-129e-4951-abe0-37a8ea602d90");
epiCmbItemGrp.IsEpiReadOnly = true;
epiCmbItemSubGrp.IsEpiReadOnly = true;
break;
case "GetNewPart":
CreateRowRulePartItem_Group_cEquals_Empty();
break;
case "Update":
Ice.Lib.Framework.EpiCombo epi_CmbItemGrp = (Ice.Lib.Framework.EpiCombo)csm.GetNativeControlReference("e405d5e7-d88d-4237-93fe-de6bfa1a0eb1");
Ice.Lib.Framework.EpiCombo epi_CmbItemSubGrp = (Ice.Lib.Framework.EpiCombo)csm.GetNativeControlReference("30594709-129e-4951-abe0-37a8ea602d90");
epi_CmbItemGrp.IsEpiReadOnly = true;
epi_CmbItemSubGrp.IsEpiReadOnly = true;
break;
case "Delete":
//oTrans_adapter.Refresh();
//oTrans_adapter.GetByID("10020002");
//oTrans.GetBaseDefault();
Ice.Lib.Framework.EpiTextBox tmpPartNo = (Ice.Lib.Framework.EpiTextBox)csm.GetNativeControlReference("38e1671b-0c3f-4ab3-b8ab-95f26285f1d2");
string PartNo = string.Empty;
PartNo = tmpPartNo.Text.ToString();
oTrans.ClearDataSets();
EpiDataView edvPart = ((EpiDataView)(this.oTrans.EpiDataViews["Part"]));
this.edvPart.Notify(new EpiNotifyArgs(this.oTrans, this.edvPart.Row, this.edvPart.Column));
oTrans_adapter.GetByID(PartNo);
//EpiDataView _partForm = (EpiDataView)(oTrans.EpiDataViews["Part"]);
//String _partFormView = _partForm.dataView[_partForm.Row]["PartNum"];
// Or
// DataView [dvVarName] = [edvVarName].dataView;
// String [VarName] = [dvVarName][[edvVarName].Row]["PartNum"];
//PartAdapter tmpPartAdapter = new PartAdapter(this.oTrans);
//tmpPartAdapter.BOConnect();
//tmpPartAdapter.PartExists(PartNo);
//tmpPartAdapter.Dispose();
// oTrans.Refresh();
//oTrans.GetByID(PartNo);
break;
