How do search a doc number? When I do a search nothing comes up???
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone: 401-596-0162 x110
Fax: 401-596-1050
www.maxsonautomatic.com
Sent: Sunday, March 23, 2003 11:51 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] OT - Workstation Enclosures
No we do not use the Fast Clock IN/Clock out program. To be honest, I've
never heard of it. The document is on epicors site. Its doc number
2099MPS. If you havent been to the site yet, you will need to setup a
username and password. Its their Eportal Webpage.
If you need any help, let me know.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Friday, March 21, 2003 2:49 PM
Subject: Re: [Vantage] OT - Workstation Enclosures
Jeremy:
We're a new Vantage customer and I was planning to go with the Thin client
setup as you described for data collection on the shop floor - where can I
find the Epicor's document that you describe regarding all of this? Also,
do you use the Fast Clock In/Clock Out custom program I've been hearing
about? If so - any comments?
Thanks alot!
Julie Lehmann, MIS DIrector
MERCURY MINNESOTA INC.
Controller
Fax: 401-596-1050
Jeremy Leonard
IT Manager
K-T Corporation
Jeremy:
Thanks alot!
----- Original Message -----
Sent: Friday, March 21, 2003 1:26 PM
Thin clients and Terminal Services have seriously helped me maintain my
sanity. When we first brought our 20 data collection terminals online it
was all PC's. I couldn't keep up with them they broke so fast. They
always
needed recalibrated(Touch screens). Employees would be playing games on
them or changing settings. Terminal Services is great. I have all of the
data collections PC's setup so that when the thin client is turned on, it
boots directly to the server and starts Data Collections. The user has
nothing else on their desktop and no start menu. All they have is Data
Collections. When they exit data collections, it goes right back into
data
collections. Supervisors all have the standard windows desktop available
from their thin client. Again, I'm able to control what they do and don't
have access too. Epicor has a great document on how to set up Windows
2000
Terminal Services with Vantage. There are a few extra steps but nothing
major.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Friday, March 21, 2003 1:36 PM
They run 2 workstations with Virtual Gibbs modeling software out there, so
I
need a reasonably good PC out there... 1G CPU with 512M RAM is sufficient.
But that leaves out using the 4th hand-me-down junkers.
I'll be getting keyboard covers. Already started using optical mice. In
theory that should be less of a problem. We'll see.
The spitting-distance CPU box idea sounds good - and the Cat5 thing.
Shirley-Jeremy - how much trouble is the setup for the terminal server and
thin clients... setting up the server and setting up the client ws's?
It's
new to me, but sounds like a good, cheaper way out. And will that run the
Virtual Gibbs graphics stuff?
Gary
Sent: Friday, March 21, 2003 7:49 AM
Our smallest Horizontal CNC has 8' x 8' travel, our largest has 25'
travel
in X and 12' in Y. We have machined parts still mounted on the back of an
18 wheeler. Trapping the smoke is not an option. As we upgrade office
computers we recycle the old machines as shop floor computers. The only
function needed is to communicate with the CNC's. There is no data stored
on the drive so no great loss if it dies.
Mark
Sent: Thursday, March 20, 2003 4:57 PM
Given the trend by OSHA and the EPA on airborne contaminants I think you
ought to consider trapping the smoke at the machine. That's the route
we
took, along with filtering the coolant to remove tramp oils which really
contribute to the smoke problem. We plumbed outlets to all of the
lathes
and move the filter unit from machine to machine. Grinders have much
bigger
particle sizes and are easier to trap.
We too have the sticky film, it just takes longer to accumulate. At
least
the visible "smoke" is mostly gone.
We have used shop PC's for ten years for data collection. I rarely
loose
a
drive, mostly monitors and mice. The keyboards have clear film covers.
The
units sit out in the open on a two shelf table. The monitor is on top
with
the keyboard and mouse. The CPU is on the second shelf where it gets
some
protection but is still breathing shop air.
Mitchell Kirby
V. P. Manufacturing
Riten Industries, Inc.
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
Sent: Thursday, March 20, 2003 4:39 PM
Gary,
Cutting fluid is a real problem for us. We built a special
enclosure
with two 4" fans for ventilation. Both fans were set up with screens.
We
found that the screens became 80% blocked in less than a week! We have
16
cnc machines in a 50k sq. ft. shop and they generate allot of coolant
smoke.
Everything in the shop is covered with a sticky film. We are planning
to
run a fresh air line from outside into the enclosure.
Mark
Sent: Thursday, March 20, 2003 4:01 PM
Gary,
The cutting fluid and metal shavings aren't causing your hard drives
to crash. Maybe proximity to a large punch or shear (vibration),
welding equipment or transformer (EMI/RFI), etc.
have fun,
john
Sent: Thursday, March 20, 2003 12:47 PM
Subject: [Vantage] OT - Workstation Enclosures
Yahoo! Groups Sponsor
and
have
and
http://docs.yahoo.com/info/terms/
ADVERTISEMENT
and
have
have
