just to chime in.. saw another similiar item when a path variable was set to a network location - so it was constantly being evaluated (as it was early on in the path variable) and slowing the system down - since the path is used to search for files. In this case the location I believe was down, compounding the issue.
----- Original Message -----
Sent: Friday, October 20, 2006 11:17 AM
Subject: RE: [Vantage] [OT] Win-XP Startup....verrrrry slow
> Trying to setup a new PC before I cut out of here for Perspectives. Same
> model as previous 18 PCs this year..HP DX5150. Prior 18 h ave been very easy
> to setup. This one though...every time it reboots it hangs for about a
> minute on the greyed out login screen, then 10-15 or more minutes on
> 'loading personal settings'. Eventually it does come up. I can't see where
> anything I did was different than any other PC setup of the same model.
> Any ideas about what would make the startup/login so long?
This happened to me once and the problem was that the system couldn't find the
ActiveDirectory server. You first have to endure the time-outs to login and
then again for each item it sets up in the login script. Make sure your DNS is
correct and that this computer is on the domain.
Mark W.
