That is what I have done. I ran it only where I had a problem with detail lines. 80% of our people do not print anything from Cyrstal that involves line level details...2-3 preople in shipping, a few in order processing and one for invoicing. I think all it does is synchs some dll files in the client with what the server side expects. No guarantees this will solve your issue but should not hurt to try.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of amfabllc
Sent: Friday, January 05, 2007 8:48 AM
Subject: [Vantage] Re: OT-Report run in Crystal has different results than when ran in Vantage
Great - I have not done that yet! Does the patch need to be run on
each of our client workstations (50) to ensure the packslip is
correct no matter where it is being printed from?
Thanks!
Ann
-Todd C.
Thanks!
Ann
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Todd Caughey" <caugheyt@...> wrote:
> Long shot but easy enough to try....
> Have you run the patch called "Crystal Decisions Database and
Export Patch.exe" on the client running the report from Vantage? I
know this resolves issues related to missing lines on several
reports and suspect it might also be related to how line level
information would be available for totaling. I've seen reports look
good in developer mode that don't work from Vantage that were fixed
with this. It is available for download from Epicor FTP site and
probably also from regular suppoprt downloads areas.
> -Todd C.
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
Behalf Of amfabllc
> Sent: Friday, January 05, 2007 7:51 AM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: [Vantage] OT-Report run in Crystal has different results
> I have revised a Crystal pack slip and am testing it in the
training
> database (Vantage 5.00.329, Crystal 8.5). It has a formula which
> calculates the total number of parts from each line of the
packslip
> (lines created due to quantites where shipped from various bins).
The
> formula is a running total field that summarizes shipdt.LNSHIPQTY,
> sum, evaluate for each record, reset on change of field
> shipdtl.PACKNUM and I positioned it on the grouping footer of
> PACKNUM. I have been very careful to open and close Vantage and
> Crystal and refresh them to make sure the data is refreshed. Since
it
> could be easy to accidently have the wrong Crystal report setup to
run
> in Vantage training, I changed a particular field to red font to
> ensure I was using the same report both places. Makes no sense to
> me. Has anyone run across anything like this? I'm pretty good with
> Report Builder so I understand the basics, but I am a beginner
with
> Crystal and may be overlooking something very simple.
> Thank you!
> Ann Rohyans
> Dexter Chassis Group
