I didn't want to use Ghost because of the cost, I found DiskImage XML, an
open source (Freeware) solution.
You will need to create a Windows PE Disk, Bart PE, google for it and then
use Sysprep as others have mentioned.
Cost =$0.0 : Time saved =$Priceless.
One link I found for it is http://www.runtime.org/dixml.htm
<http://www.runtime.org/dixml.htm>
Jim
_____
Cliff Drumeller
Sent: Tuesday, July 11, 2006 2:18 PM
Subject: RE: [Vantage] Re: OT: Disk Imaging
People
You sysprep the original computer that you make the image from. The
when you fire up the imaged computer the first time it requests the
Microsoft 25 character code. Sysprep was made for just this thing. SID's
are then not an issue.
Cliff
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Dale Schuerman
Sent: Tuesday, July 11, 2006 9:07 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
It has been a couple years since I used Ghost but the process required
was.
* Take PC off network
* Install Ghost Image
* Rename Computer
* Place back on network.
* The computers were all different brands and models. So it was
then required to get all of the correct hardware drivers, including the
customary re-boot for each driver.
The new Ghost might be better. It took about 1 hour per computer and
was much better than installing all software from scratch.
I have never used it but I believe the company that created
PartitionMagic also has Image Copy software.
Hope this helps,
Dale
<mailto:vantage%40yahoogroups.com> ] On
Behalf
Of maurojm
Sent: Tuesday, July 11, 2006 10:01 AM
Subject: [Vantage] Re: OT: Disk Imaging
John,
There are SID issues with ghgosting machines, but there is a product
called "Ghost Walker" (I think they still call it that) that will go
thru and change the SIDs.
As far as licensing goes, you pay for the number of PCs that will
connect to the ghost "server" at one time. It doesnt matter how many
times you use the image.
Hope that helps
Jeff
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
<mailto:vantage%40yahoogroups.com> ,
"John Mansfield" <johnm@...> wrote:
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys <http://www.ramsys.com> com
<http://www.ramsys <http://www.ramsys.com> com>
Jim
_____
Cliff Drumeller
People
Cliff
Behalf
Of Dale Schuerman
was.
* Rename Computer
Hope this helps,
Dale
Behalf
Of maurojm
John,
Hope that helps
Jeff
> Hi to everyone,
> Sorry I am naive but what about license issues.
> If you use the same image for X number of computers what happens?
> Don't you run into issues with the SID etc.
> Thanks,
> John Mansfield
> General Sheet Metal
Attention:
by MailMarshal SMTP
