[OT] Different Printing Problem - PDF files
Yes but that did not help. But since then (like about 15 minutes ago) I had the user uninstall Acrobat Reader (5.0) and install Reader 6.0 and the problem has gone away. Apparently there was some incompatibility between 5.0 and his Windows-2000 PC and/or printer drivers. I should have tried that a lot sooner.
-Todd C.
Sent: Monday, March 29, 2004 10:05 AM
Subject: Re: [Vantage] Re: [OT] Different Printing Problem - PDF files
Todd,
Have you tried to print the document as image?
There is a such option on print dialog box.
Mike Tonoyan / All American Products Co.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Saturday, March 27, 2004 11:33 AM
Subject: RE: [Vantage] Re: [OT] Different Printing Problem - PDF files
> Not the one "driving" the printer, yet. But since the original post I
ahve seen some very strange things on the sharing PC. All his major fonts
(like Arial) are now named "Arial (PCL6)". I have a suspicion that the
"sending" PCs are running into this font issue in the PCL6 driver. Normally
I would not install the PCL6 and instead use PCL5 but the Laserjet 2100 CD
only has PCL6 for Windows-2000. My next planned step was to uninstall it
and then NOT install via the HP CD install process but rather directly
search for various driver .inf files.
> Thanks for tjhe suggestion.
> -Todd C.
> From: ariaconsulting_ab [mailto:lrogers@...]
> Sent: Saturday, March 27, 2004 1:31 PM
> Subject: [Vantage] Re: [OT] Different Printing Problem - PDF files
> Todd,
> Have you tried to re-install the printer drivers on that system?
> Lorne Rogers
> Aria Consulting & Implementers Ltd.
> Authorized Epicor Vista & Vantage Consultants and Re-sellers
> --- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...> wrote:
> > OK, as long as printing is on people's mind....
> > Since yesterday I have had one printer (HP LJ 2100) that will not
> correctly print PDF files. It either leaves off most of the text or
> substitutes garbage characters from strange fonts. Graphic
> components are fine and text in graphics is unchanged. But any added
> text will not work. Pirnting to other printers (like HP LJ 4000)
> works fine. The printer is shared off of a user's LPT1 port. That
> user can print PDF OK but anyone connecting thru network gets
> garbage. Even using Acrobat instead of just Acrobat Reader does not
> help. Also, it was printing PDFs very light until I knocked printer
> resolution down to 600dpi from 1200. Perhaps a memory issue but only
> for network printing?
> > Anyone else ever have problems with PDF printing?
> > Thanks,
> > Todd Caughey
> > Harvey Vogel Mfg. Co.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Sponsor
> ADVERTISEMENT
< http://rd.yahoo.com/SIG=12cvpj9t1/M=281792.4727319.5879690.1261774/D=egroup
web/S=1705007183:HM/EXP=1080502261/A=2058224/R=0/SIG=116652qbq/* http://my.ya
hoo.com/promo/ppets.html> click here
< http://us.adserver.yahoo.com/l?M=281792.4727319.5879690.1261774/D=egroupweb
/S=:HM/A=2058224/rand=310918735>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
< http://docs.yahoo.com/info/terms/> .
> Yahoo! Groups Links
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Since yesterday I have had one printer (HP LJ 2100) that will not correctly print PDF files. It either leaves off most of the text or substitutes garbage characters from strange fonts. Graphic components are fine and text in graphics is unchanged. But any added text will not work. Pirnting to other printers (like HP LJ 4000) works fine. The printer is shared off of a user's LPT1 port. That user can print PDF OK but anyone connecting thru network gets garbage. Even using Acrobat instead of just Acrobat Reader does not help. Also, it was printing PDFs very light until I knocked printer resolution down to 600dpi from 1200. Perhaps a memory issue but only for network printing?
Todd Caughey
I was having a similar problem with PDFs printing to an HP5000NG on a NT4.0
network from only one user. The print would be full of squares and other
line -drawing characters. Actually had one PDF that would print in reverse
image (white on black!) when printed on the 5000. Everybody else worked just
fine. The only thing that I could find that was different on this one
computer was it had MS Office XP installed; everyone else has Office 2000. I
pulled my hair out for weeks trying to solve the issue. I finally
downloaded the latest drivers from HP and re-installed on the server. That
solved the problem.
Jim Stetter
IT Manager
Snow Filtration, a division of Reemay, Inc.
(513) 777-6200 ext 268
<mailto:jstetter@...> jstetter@...
Sent: Wednesday, March 24, 2004 11:54 AM
Subject: [Vantage] [OT] Different Printing Problem - PDF files
Todd Caughey
Please note: This message may contain information which is privileged and confidential. If you are not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer.
Todd,
I have the same printer here - connected locally to my pc - I printed a
text.pdf from another pc to my printer and it prints fine. I have only
seen this happen to me when I was taking a scan of a text document then
creating a pdf. - Probaly does not help but that I would let you know-
Have a Nice Day,
Dina Hieber
Vamco International, Inc.
Phone (412) 963-7100
Fax; (412) 963-7160
www.vamcointernational.com
_____
Todd Caughey
_____
Yahoo! Groups Links
Todd,
Lorne Rogers
> Thanks,
> Todd Caughey
Todd,
Lorne Rogers
> Thanks,
> Todd Caughey
Not the one "driving" the printer, yet. But since the original post I ahve seen some very strange things on the sharing PC. All his major fonts (like Arial) are now named "Arial (PCL6)". I have a suspicion that the "sending" PCs are running into this font issue in the PCL6 driver. Normally I would not install the PCL6 and instead use PCL5 but the Laserjet 2100 CD only has PCL6 for Windows-2000. My next planned step was to uninstall it and then NOT install via the HP CD install process but rather directly search for various driver .inf files.
-Todd C.
Todd,
Lorne Rogers
> Thanks,
> Todd Caughey
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cvpj9t1/M=281792.4727319.5879690.1261774/D=egroupweb/S=1705007183:HM/EXP=1080502261/A=2058224/R=0/SIG=116652qbq/*http://my.yahoo.com/promo/ppets.html> click here
<http://us.adserver.yahoo.com/l?M=281792.4727319.5879690.1261774/D=egroupweb/S=:HM/A=2058224/rand=310918735>
_____
Yahoo! Groups Links
Yeah, kinda thought it was going to be something to do with the PCL
level. That is why I asked. It is trying to "interpret". have you
checked HP website to see if there is a 5 level driver?
Or {yuck} you may have to go to 6 on all the systems. Or, have you
tried a PS driver?
Lorne Rogers
Authorized Epicor Vista/Vantage Consulting, Implementation and Sales
files.
> -Todd C.
> From: ariaconsulting_ab [mailto:lrogers@a...]
> Todd,
> Lorne Rogers
or
added
not
printer
only
> > Thanks,
> > Todd Caughey
access. )
> ADVERTISEMENT
18735>
> _____
> Yahoo! Groups Links
If I have my "druthers" I rather have all PCL5. Not a big fan of postscript, I think it is slower. I'll check HP for newer or more complete drivers.
For now I'm out of here. Vantage 6.0 seems to be done and running so I get to come back tomorrow and re-do CR forms and install new client on users' PCs. Maybe I'll have time for the driver thing then.
Thanks for the help,
-Todd
Sent: Saturday, March 27, 2004 4:22 PM
tried a PS driver?
Lorne Rogers
files.
> -Todd C.
> Todd,
> Lorne Rogers
or
added
not
printer
only
> > Thanks,
> > Todd Caughey
access. )
> ADVERTISEMENT
18735>
> _____
> Yahoo! Groups Links
Service < http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cu3f2cs/M=268585.4521611.5694062.1261774/D=egroupweb/S=1705007183:HM/EXP=1080512524/A=1950450/R=0/SIG=124efgk3i/*http://ashnin.com/clk/muryutaitakenattogyo?YH=4521611&yhad=1950450> click here
<http://us.adserver.yahoo.com/l?M=268585.4521611.5694062.1261774/D=egroupweb/S=:HM/A=1950450/rand=209043840>
_____
Yahoo! Groups Links
I have had this problem in the past and the fix (or work around) is when
printing out of Adobe to check the "Print as image". This seems to solve
the font problem. I have had this happen to HP 4, Kyocera digital copier
and my HP 2100.
Hope this helps.
John
>-Todd C.
>Todd,
>Lorne Rogers
> > Thanks,
> > Todd Caughey
><http://groups.yahoo.com/group/vantage/files/.>http://groups.yahoo.com/group/vantage/files/.
><http://groups.yahoo.com/group/vantage/messages>http://groups.yahoo.com/group/vantage/messages
><http://groups.yahoo.com/group/vantage/links>http://groups.yahoo.com/group/vantage/links
>ADVERTISEMENT
><<http://rd.yahoo.com/SIG=12cvpj9t1/M=281792.4727319.5879690.1261774/D=egroupweb/S=1705007183:HM/EXP=1080502261/A=2058224/R=0/SIG=116652qbq/*http://my.yahoo.com/promo/ppets.html>http://rd.yahoo.com/SIG=12cvpj9t1/M=281792.4727319.5879690.1261774/D=egroupweb/S=1705007183:HM/EXP=1080502261/A=2058224/R=0/SIG=116652qbq/*http://my.yahoo.com/promo/ppets.html>
>click here
><<http://us.adserver.yahoo.com/l?M=281792.4727319.5879690.1261774/D=egroupweb/S=:HM/A=2058224/rand=310918735>http://us.adserver.yahoo.com/l?M=281792.4727319.5879690.1261774/D=egroupweb/S=:HM/A=2058224/rand=310918735>
> _____
>Yahoo! Groups Links
><http://groups.yahoo.com/group/vantage/>http://groups.yahoo.com/group/vantage/
><<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/> .
>ADVERTISEMENT
><http://rd.yahoo.com/SIG=12chl4bfg/M=267637.4673018.5833253.1261774/D=egroupweb/S=1705007183:HM/EXP=1080502522/A=1945637/R=0/SIG=11tfh3gpg/*http://www.netflix.com/Default?mqso=60178397&partid=4673018>139a30.jpg
>Yahoo! Groups Links
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>vantage-unsubscribe@yahoogroups.com
> <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
John Himebaugh
2727 De Anza Road, R-12
San Diego, CA 92109
858.581.1508 Voice & Fax
619.994.4294 Cell
johnsd@...
Todd,
> -Todd C.
> Todd,
> Lorne Rogers
> > Thanks,
> > Todd Caughey
> ADVERTISEMENT
> _____
> Yahoo! Groups Links
> Yahoo! Groups Links
